Not Well Grounded #767386 11/24/06 11:36 PM
rumrunner Offline OP
I've been having odd little electrical problems with my pick-up for over a year, but up until now I've been able to work around them. However, yesterday it went completely dead three times, twice while parked and once while driving. After a jump, it would start and run normally until some apparently random point when it would just die again (suddenly, at least in the case of when I was driving).
The one clue I have is that when I plug my cell phone into the AC charger, radio reception deteriorates significantly. Also, since getting the charger last year, I've on occasion noticed the radio signal cut out to the speakers very briefly in periodic cylcles- IE there is a half second of silence every 20 seconds or so. One other thing is that I've had to have the starter rebuilt twice in the last year.
I'm not very knowledgable about electrical systems. I have vol 1 of the service manual but not the second with all the electrical info. I have a Haynes manual with a chapter about it, but the text is very generic and the wiring diagrams don't show anything including the radio or cigarette lighter.
Is this enough to indicate where to start looking for a short in the system? Is there a good reader friendly resource to efficiently learn more about electrical systems? I'm going to talk to my mechanic about it in the morning, but last time I mentioned the electric glitches, he didn't seem to think they indicated anything.
1992 Mighty Max 4x4
3.0 5-speed
Herculined bed
Re: Not Well Grounded [Re: rumrunner] #767387 11/25/06 12:36 AM
I would start with the battery cables and work away from there. There could be corrosion inside the cables and a resultant loss of power transmission. To check the cables manually, take hold of a cable and move a section back and forth while you're clasping it. If you feel a scratchiness or hear something inside the cable, they're corroded. If this test does not have any result, check the chassis ground connections for corrosion. Thirdly, how old is your battery?
Re: Not Well Grounded [Re: rxinhed] #767388 11/26/06 05:57 PM
The cables do not have much play in them. I could move the negative one around a little and it felt supple. The battery is about 2 years old- I had to get a new one after one of the rods that mount the battery came loose and ended up wearing through the insulation of the negative cable, completely toasting the old battery. I don't exactly remember how we fixed the cable, but I can't find any evidence of damage to the insulation now and the connection looks pretty solid.
I just picked up a multimeter from my dad yesterday. I'll see if I can figure anything out with it...
1992 Mighty Max 4x4
3.0 5-speed
Herculined bed
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5957 MB (Peak: 0.6503 MB) Data Comp: Off Server Time: 2026-11-16 01:22:02 UTC
