Page 2 of 4 1 2 3 4
Re: gear ratios in taco elocker diffs? [Re: Rauch_Off_Road] #767421 11/26/06 04:40 PM
superv43 Offline
They are most certainly available in 4.56 from the dealer as I purchased a brand new one and retrofitted to my 85 pickup a while back.
Not sure what vehicles came with 4.56 ratio but here are the Toyota part #s for the complete third members;
- 4.56 ratio -> #41110-3D010
- 4.30 ratio -> #41110-3D080
- 4.10 ratio -> #41110-3D030
Re: gear ratios in taco elocker diffs? [Re: superv43] #767422 11/26/06 06:53 PM
toyrunner Offline
How many $ for the 4.56?
Thanks
Danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: gear ratios in taco elocker diffs? [Re: toyrunner] #767423 11/27/06 02:49 PM
superv43 Offline
I paid around $780 for a new elocker third from the Toyota dealer a while back. List is around $1200, most dealers will do 25-30% off of list if you get to know them.
If you can work with the 4.56 ratio its not a bad deal when compared to something like an ARB where you are looking at $800 or more just for the ARB carrier and compressor, then you have regearing and labor costs on top of that. (and with the ARB probably at least one teardown every few years to fix leaky o-rings..at least thats been my experience)
The elocker third is complete with brand new factory gears already setup by Toyota.
Re: gear ratios in taco elocker diffs? [Re: superv43] #767424 11/27/06 04:53 PM
Rauch_Off_Road Offline OP
have any of you heard of problems fitting an elocker into the front with an SAS?
(aka suprathepeg, aka Sean)
Re: gear ratios in taco elocker diffs? [Re: Rauch_Off_Road] #767425 11/27/06 05:50 PM
G
Greg_Canada Offline
I think something hits the leafs spring.
Most people use the high pinion e-locker from an FJ80, because the gears are stronger as well (reverse rotation)
89 4Runner
Re: gear ratios in taco elocker diffs? [Re: Rauch_Off_Road] #767426 11/27/06 10:52 PM
dcg9381 Offline
It'll work with minor changes - there are writeups on it.. Search google.
22REturbo.net
1988 4Runner
Re: gear ratios in taco elocker diffs? [Re: Rauch_Off_Road] #767427 11/28/06 01:23 AM
84toyota Offline
see this link: Inchworm 3rds
They will set up the gears up to 5.29's for you... good chunk of change though...
Note that you will have to modify your axle housing...
Ken
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: gear ratios in taco elocker diffs? [Re: Rauch_Off_Road] #767428 11/28/06 04:14 AM
Are they available in the same sizes as regular factory diffs? 4.10-4.88.
4:10-4.56 but i think jim at inchworm told me i could get factory 4.88
http://www.inchwormgear.com/store/product_info.php?products_id=38
Re: gear ratios in taco elocker diffs? #767429 11/28/06 04:25 AM
dcg9381 Offline
It looks like going to 4.88 is a regear.
Jim @ inchworm did the diffs on my 1981. I was happy with the results.
I need 4.56 for my current setup - moderate lift SAS (33's) - I paid $450 for my toyota e-locker 3rd locally, had I known that I could buy at a dealer for under $800 or so, I really would have considered that option.
I'm assuming a regear is going to cost $300-$400, assuming that I don't do it myself..Regearing is something I've avoided so far...
22REturbo.net
1988 4Runner
Re: gear ratios in taco elocker diffs? [Re: dcg9381] #767430 11/28/06 04:50 AM
IDK why anyone buys ARB when they can get an e-locker made by toyota for the same price or even less. Just the no air hoses alone makes it worth while.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6403 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-05-29 14:40:26 UTC
