Truck pulsates while stopping #767635 11/26/06 06:01 AM
Jake97T Offline OP
pulsation is not in the pedal which leads me to believe the rotors are fine....shoe contamination in the rear???
As i come to a slow stop the truck pulses.
Re: Truck pulsates while stopping [Re: Jake97T] #767636 11/26/06 06:10 AM
CJMT100 Offline
Last time the brake fluid was flushed? When braking whats doing the majority of the work-if its the fronts the rears arent engaging enough, there is a special valve that will fix this..
Re: Truck pulsates while stopping [Re: CJMT100] #767637 11/26/06 06:22 AM
Jake97T Offline OP
i made a bracket to compensate for the lifted rear...fluid flush a year ago. tires out of round?
Re: Truck pulsates while stopping [Re: Jake97T] #767638 11/26/06 06:46 AM
CJMT100 Offline
Couldbe tires and or wheels out of round, but that would mean it pulsates all the time and most notably at higher speeds. Course they could be out of balance too..
U joints?
Re: Truck pulsates while stopping [Re: Jake97T] #767639 11/26/06 06:51 PM
Brian_M Offline
I've had this issue too, for about 50k miles. In that time the truck has had 2 major services at reputable shops (the first right when I bought it and I had them do Everything as I was getting ready for a 4000 mile trip, moving all my crap across the country), all fluids have been flushed, all wear items inspected and replaced as needed, brand new tires that were ballanced on the RoadForce ballancer (it applies force to the tires, as if they were driving down the road), brakes have been inspected a half dozen times and the rotors have next to no runout, pads have been replaced, etc...
In other words, no expense spaired to keep the truck in tip top shape, and yet when braking, I still get the pulsation/shuddering. At this point, I'm used to it and have just come to expect it from the truck. It doesn't affect performance in any way that I've noticed. But if you do find something, please post it up. <img src="/forums/images/graemlins/smile.gif" alt="" /> I'd love to fix whatever causes this issue.
Cheers <img src="/forums/images/graemlins/cheers.gif" alt="" />
Cheers,
Brian M
'97 T100 SR5 4x4, with Buckets
Re: Truck pulsates while stopping [Re: Brian_M] #767640 11/26/06 10:18 PM
G
Greg_Canada Offline
At very low speeds i can feel the lugs on my M/T's pulsating...
89 4Runner
Re: Truck pulsates while stopping [Re: Greg_Canada] #767641 11/26/06 11:56 PM
L
lawnmowerman Offline
Sounds like warped rotors to me.I have had a few Toys with warped rotors.(pretty common) In my experience I have never felt it in the pedal.If your rotors have been turned in the past due to warpage than I would suspect that they are warped again.Turning warped rotors is a bad idea.Buy new!I have drilled+slotted rotors and OEM pads on my T100 and have been very pleased with the results.
Re: Truck pulsates while stopping [Re: lawnmowerman] #767642 11/27/06 12:28 AM
Jake97T Offline OP
thought about doing the fleabay slotted rotors, wasnt sure on quality, powerslot rotors are a bit under 200...how is everyone else's experience with aftermarket rotors?
Re: Truck pulsates while stopping [Re: Jake97T] #767643 11/27/06 02:18 AM
ErikB Offline
Toyota Moderator
I would suspect rotors as well. Mine was doing that too and I finally replaced the original rotors with some Brembo rotors (not drilled or slotted) and Hawk HPS pads from tirerack.com. No problems since and the pads gave a little increase in brake power, so I'm pleased.
http://home.4x4wire.com/erik
Re: Truck pulsates while stopping [Re: ErikB] #767644 11/29/06 01:08 AM
CJMT100 Offline
Same here, I replaced mine with brembo blanks and LTS pads and was very happy.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6344 MB (Peak: 0.7580 MB) Data Comp: Off Server Time: 2026-10-21 21:27:42 UTC
