t-case difference v6 vs 4cyl
#767882
11/27/06 05:23 PM
I just picked up an 88 4runner SR5 V6, and the t-case wont shift into 4L. I also have an 86 4cyl P/U that i'm parting out, and i'm wondering if the t-case is the same or not.
Thanks in advance
88 4runner sr5 v6 needs a lift!
-formerly 86yodaputruck
Re: t-case difference v6 vs 4cyl
[Re: uglytruck]
#767883
11/27/06 06:41 PM
What you should do is study what you have and on this site look at the toyota 4x4 spec... link ther you can find out what you have... http://www.4x4wire.com/toyota/faq/parts/And you can decide what you can do or give use more info
[Re: uglytruck]
#767884
11/27/06 07:05 PM
The V6 is most likely a forward shift TCase, the 4Cyl is most likely a top shift TCase. You can swap the shift rails from the V6 to make the 4Cyl work. Need to break open both TCases to make it work. Marlin Tech section has diagrams on this. However, if your V6 is an Auto Tranny, I have no idea what it entails.
[Re: uglytruck]
#767885
11/27/06 07:14 PM
Might be the shifter is stabbed into the shift rails improperly. Pull out the shifter and see if that is the case.
[Re: 4Crawler]
#767886
11/27/06 08:40 PM
Might be the shifter is stabbed into the shift rails improperly. Pull out the shifter and see if that is the case. I'll have to check this out when i get home.. by the way, both trucks ar M/T
[Re: Staceman]
#767887
11/27/06 11:26 PM
Toyota Moderator
The V6 is most likely a forward shift TCase, the 4Cyl is most likely a top shift TCase. You can swap the shift rails from the V6 to make the 4Cyl work. Need to break open both TCases to make it work. Marlin Tech section has diagrams on this. However, if your V6 is an Auto Tranny, I have no idea what it entails. The 4 cylinder and V6 cases are entirely different. The 4 cylinder case is gear driven and the V6 case is a chain drive. They have different bolt patterns and spline counts as well. The only way to bolt up a 4 cylinder t-case to a V6 transmission is with an aftermarket adapter.
[Re: DirtyHarry]
#767888
11/27/06 11:43 PM
Toyota Moderator
Ditto what Harry & 4Crawler said!
[Re: ErikB]
#767889
11/28/06 06:21 AM
Ditto what Harry, 4Crawler, & Erik B said!!!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
"Serenity through Sobriety"
[Re: OOP'S]
#767890
11/28/06 08:43 PM
Ouch, sorry <img src="/forums/images/graemlins/ignore.gif" alt="" />. I got 4 and 6 cyl confused with Top and Forward. Ditto above.
