Shifters after 3" body lift. #767979 11/28/06 12:50 AM
throwin_roost Offline OP
What have you all done to fix the gear shifter problem when doing a 3" body lift? I cut and welded the two 3" spacers into my shifters like the kit said to do, but I was still unable to replace the shift boot and center plastic. I had to cut some extra metal to engage my bottom gears and cut up a rubber floormat to go over the hole. The directions in the kit make it sound so easy.
93 Rodeo 3.2L, 3" body lift, 3" Indy4x lift on 33's, flowmaster50, stainless brakes and clutch lines,
Re: Shifters after 3" body lift. [Re: throwin_roost] #767980 11/28/06 01:42 AM
RobG Offline
sometimes its necessary to heat/bend the shifters after welding in the extension to fine tune the shift.
-Rob
Re: Shifters after 3" body lift. [Re: RobG] #767981 11/28/06 01:47 AM
strawmyers Offline
Isuzu Moderator
I bent the tranny shifter a little at a time in a press until it worked. The t-case shifter I just left as-is and cut some metal out of the floor and some of the rubber out of the thick boot. That was with a 1.25" BL... so I'd expect greater measures necessary with 3".
Sean Strawmyer
Re: Shifters after 3" body lift. [Re: strawmyers] #767982 11/28/06 06:48 PM
Smiley Offline
HereÆs a little trick that has worked quite well for the boot itself on mine:
(Once you have the shifter lever positions worked out...)
Invert the two raised sections that surround the shifter levers so that they both point downwards. --- Secure the boot in this inverted position just below the thick section of the two shafts as best as you can, making sure to allow for their required range of movementà
Then secure the boot itself to the body, affixing it all of the way around the recess opening so that it doesnÆt pop out of position. --- I used heavy-duty Black Gaffing Tape for all-of-the-above, and it worked like a charm.
(I probably ought to add this tip to my Body Lift Write-Up)
The bad news is, if youÆve already cut into the recess (or the boot!), this might not work as well for you as it did for me.
Hope it helps <img src="/forums/images/graemlins/kewl.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Shifters after 3" body lift. [Re: Smiley] #767983 11/28/06 11:05 PM
Paddler Offline
I had to ever so slightly notch out the rearward Passenger corner) section of the shifter opening and I had to discard the inner boot. BTW, what's "gaffing" tape?
1995 Honda Passport;
Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling
Yours truely
http://www.zutah.com
Re: Shifters after 3" body lift. [Re: Paddler] #767984 11/29/06 06:42 PM
Smiley Offline
Black Gaffing Tape û it's heavy-duty Duct TapeÆs brutish, a$$-whoopinÆ big brother <img src="/forums/images/graemlins/wink.gif" alt="" />
Mostly it is used by professional stage workers to assemble and/or affix lighting displays, power cord assemblies, sound systemsà you name it û the stuff has a million uses and is virtually indestructible!
>> Info about Gaffer's Tape <<
I scored 12 rolls (for THREE Dollars!) when a local department store went out of business...
But IÆm now down to less than 2 <img src="/forums/images/graemlins/zombie.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6111 MB (Peak: 0.6981 MB) Data Comp: Off Server Time: 2026-05-29 18:51:39 UTC
