Spindle bolt #768144 11/28/06 04:44 PM
Hal2000 Offline OP
Does anyone know of a place besides the stealership where I can get these bolts at. They want almost 10 bucks a bolt for these at the stealership. In case you wonder what I'm talking about its the bolts in the upper control arm.
98 Sportage
Re: Spindle bolt [Re: Hal2000] #768145 11/28/06 10:59 PM
Dave Scott Offline
i'm thinking your best bet will be to go to a bolt store and compare them.
Re: Spindle bolt [Re: Dave Scott] #768146 11/28/06 11:25 PM
logansportage Offline
Make sure you get Grade 8 hardware.
Re: Spindle bolt [Re: logansportage] #768147 11/28/06 11:34 PM
Hal2000 Offline OP
Wel I thought about going to the handware store and get a bolt but these bolts have the adjustment marks used for alignments.
98 Sportage
Re: Spindle bolt [Re: Hal2000] #768148 11/29/06 12:32 AM
If I understand correctly you are looking for the cam bolts that are used for setting the alignment for the front end.
A tire store that does front end alignments might be able to get them for you for a lot less. Check with them. They might be a standard type bolt for them.
Re: Spindle bolt [Re: logansportage] #768149 11/29/06 03:50 AM
Hal2000 Offline OP
Thats what I was trying to express.. I'll see what I can find.
98 Sportage
Re: Spindle bolt [Re: Hal2000] #768150 11/29/06 05:05 PM
Best of luck.
Re: Spindle bolt [Re: logansportage] #768151 11/29/06 10:55 PM
Hydra747 Offline
Good Luck. I am always careful of compromise when it comes to issues like Structure/integrity! Spend the $10 bucks on the bolts ..........and like just don't go to the movies and such <img src="/forums/images/graemlins/nana.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6215 MB (Peak: 0.6994 MB) Data Comp: Off Server Time: 2026-06-07 07:06:56 UTC
