Overflow filling up #768366 11/29/06 03:48 AM
2
2timer Offline OP
I replaced the radiator a month ago and have been adding a little fluid every week or so. I checked the overflow today and it was almost full.
What's the deal???
Re: Overflow filling up [Re: 2timer] #768367 11/29/06 04:18 AM
TommyM Offline
Have you replaced the rad cap? If not, try that.
If the cap is good, you may have a blown head gasket or cracked head, so that engine compression is pressurizing your cooling system, and forcing the cap to relieve pressure by blowing coolant into the overflow. You can buy a chemical test kit at a real auto parts store (like NAPA) that will tell you if you have combustion products in your coolant. Best I recall, it was like $30 ten years ago.
90 LWB Montero, 270k, 265/75R16, 16x8 ARE Bajas, Budget Lift, Towbar, Aux Brakes (towed with camper), Jotto Desk, remote oil filter
92 bone stock base model beater
Parting out 4 more
Re: Overflow filling up [Re: TommyM] #768368 11/29/06 04:23 AM
Jamez Offline
They also have pressure testers that replace the cap to monitor pressure. When my car blew the headgaskets the guage jumped around a lot and I steadily lost fluid as it leaked into the combustion chamber.
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: Overflow filling up [Re: Jamez] #768369 11/29/06 11:51 PM
sparkem Offline
Something to think about. My head gasket was letting exhaust in my water system and forcing water to fill and over flow the over flow tank.
Re: Overflow filling up [Re: 2timer] #768370 11/30/06 03:30 AM
2
2timer Offline OP
Thanks for the bad news guys. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I hope this doesn't get any worse. I can live with losing the little bit of fluid, and the smell of coolant in the cab - at least for the winter. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Overflow filling up [Re: 2timer] #768371 11/30/06 06:09 AM
It will get worse, and rather quickly, and all the time it's getting worse, the antifreeze is getting into the oil and attacking the main and rod bearings, and rusting stuff, and diluting the oil (AND sitting on the bottom of the pan at the pickup, where it pretends to be oil and pretends to lube the whole motor).
I would not ride it to the end if I wasn't planning on a complete rebuild instead of just head gaskets.
I just spent $412 on head work, and $477 on parts so far (head gasket set, ALL the hoses, ALL the belts, ALL the belt idlers and tensioners, water pump (and helicoils to fix the two stripped threads in the back half minibolt holes), crossover pipe gasket, rtv, 2gal antifreeze, case of Castrol) and I still need thermostat, oil filter, and pan plug copper washer, and probably an ohtwo sensor, since my CEL is about to burn out from water/oil fouling of the whole exhaust. AND about 8 hours to put it back together and time it. Including at least 1/2hr of cursing, holding moshed fingers/knuckles/elbows. I save a net of at least 15min by taking off the hood, and avoiding head dings on the latch...
Re: Overflow filling up [Re: fasteddy] #768372 11/30/06 12:55 PM
JAVYPRO Offline
I've been there and I am almost done with mine. Do not wait until it worsen because it will cost big $$$ then. I had exactly the same problem, when I dumped the oil it looked like Yooho (spelling, since became lactose intolerant I have not seen one of those) <img src="/forums/images/graemlins/smile.gif" alt="" /> And the exhaust fumes? ohhh sweet and fruity <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
I got a head from Clearwater Cylinder Heads for $375 plus all the other bells and whistles I am up to like $450, Way better than a new engine.
Go ahead and take care of that as soon as you can. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Overflow filling up [Re: 2timer] #768373 11/30/06 01:07 PM
Y
yankneck696 Offline
Check your heater core for leakage. If the scent is in the cab, I would suspect it first.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.009s) Memory: 0.6227 MB (Peak: 0.7184 MB) Data Comp: Off Server Time: 2026-11-02 02:59:38 UTC
