chain eating timing cover #768404 11/29/06 02:11 PM
Buffalo86 Offline OP
I've been through this before, 25-30k miles ago.
Tell me what you think of this idea. The chain is too long because the cylinder head has been shaved below minimum specs. OR the cylinder head was replaced by a PO who put on a 22RE head. At the machine shop I saw two numbers yesterday 3.90-3.950' head thickness and 3.785'.
Does anybody have the factory manual for an '86 that would have the info? [img]http://[/img]
Re: chain eating timing cover [Re: Buffalo86] #768405 11/29/06 02:30 PM
I just took a couple pictures but I'm not sure how to post them
Re: chain eating timing cover [Re: Buffalo86] #768406 11/29/06 02:45 PM
Adam F Offline
Here's a how to I wrote on another forum to post pics
http://www.tri-statecrawlers.com/forum/showthread.php?t=142
If you cant figure it out email them to me 4runneradam@gmail.com
97 4R, stock, daily driver
Re: chain eating timing cover [Re: Adam F] #768407 11/29/06 03:06 PM
Welded cover and where the chain was eating the head [Linked Image]
Re: chain eating timing cover [Re: Buffalo86] #768408 11/29/06 03:18 PM
Re: chain eating timing cover [Re: Buffalo86] #768409 11/29/06 06:40 PM
DRTDEVL Offline
I think it is a later head because of the kidney-shaped combustion chamber, but I am not sure.
The best/easiest way to tell is if the ports are oval or teardrop shaped... The early had oval ports, while the later had teardrop shaped ports.
Another thought... The exhaust manifold would have 1 bolt in the middle for an early head, while the later have 2 (like the pic).
Re: chain eating timing cover [Re: Buffalo86] #768410 11/29/06 08:08 PM
toyrunner Offline
If I am not mistaken, the 86 block and head is the same whether 22R or 22RE.
Must have too much shaved off.
Danny
look here engnbldr.com
Re: chain eating timing cover [Re: toyrunner] #768411 11/29/06 08:46 PM
eightyeight Offline
yeah, 22r and 22re does not matter.
the only difference in height and combustion chamber is pre '85, and '85+.
How are the chain guides and tensioner?
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: chain eating timing cover [Re: Buffalo86] #768412 11/29/06 08:56 PM
dcg9381 Offline
There are two versions of timing chains.
The head could be shaved too much.
The block could be decked too much.
Could be an incorrect head, as you've mentioned... You need to figure you which block/head combo you have as well as measure your timing chain.
22REturbo.net
1988 4Runner
Re: chain eating timing cover [Re: eightyeight] #768413 11/30/06 06:09 PM
They were shot. I went and bought everything. new timing chain set. new gasket set. also a 0.02 steel shim.
I'm putting the thing back together now.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6314 MB (Peak: 0.7395 MB) Data Comp: Off Server Time: 2026-06-09 21:33:12 UTC
