Flashing AT light/Check Engine #768561 11/30/06 01:55 AM
danamr Offline OP
95/3.0 Montero.
On the way to work today the AT light started flashing during braking. I am also getting a check engine at times, but neither is on all the time. Only happening during braking. The manual is no help, just says the ECU has detected a fault.
Any ideas?
Dana
Seattle
Re: Flashing AT light/Check Engine [Re: danamr] #768562 11/30/06 06:46 PM
W
Winston Offline
Check the fluid level.
Have you ever changed the AT fluid?
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: Flashing AT light/Check Engine [Re: Winston] #768563 12/01/06 08:20 PM
If you change it, make sure you use compatible fluid if not Mitsu OE fluid. If you mess up and put incompatible fluid, there's a 99% certainty that you will be rebuilding your transmission. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Flashing AT light/Check Engine [Re: off-roader] #768564 12/03/06 12:30 AM
danamr Offline OP
ATF was changed about 15K miles ago, with Mits ATF, and levels are good.
Once the engine warmed up the warning lights stopped, and only happened during a period that local temps never got above freezing. I am wondering if a sensor got covered with ice that finally got melted off. I have had the car out Friday, and Sat and there is no sign of the problem.
Re: Flashing AT light/Check Engine [Re: danamr] #768565 12/06/06 12:26 AM
W
Winston Offline
There have been other instances of water affecting the AT temp light, so you are probably OK.
'95 Montero LS 160k
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6065 MB (Peak: 0.6712 MB) Data Comp: Off Server Time: 2026-06-10 06:16:43 UTC
