83 Pickup Alternator Removal #768577 11/30/06 02:21 AM
P
parshal Offline OP
OK, what's the secret? I've got it disconnected but can't seem to get it out of the engine bay. It looks like I can drain the radiator and remove the bottom hose but that still doesn't look 100% foolproof.
Help?
Re: 83 Pickup Alternator Removal [Re: parshal] #768578 11/30/06 02:58 AM
4Crawler Offline
Usually easiest to drain and pull the lower hose, especially w/ power steering. Drain into a bucket then refill the rad. after you are done. May be able to squeeze the alt by the lower hose or if no p/s, pull it out the top.
Re: 83 Pickup Alternator Removal [Re: parshal] #768579 11/30/06 02:58 AM
kyle-22r Offline
yep, have to pop the lower radiator hose off and slip it out. even then you have to get it lined up just right. learned that one the hard way a few years ago, took me 4 hours! i can yank an alternator in about 20 minutes now.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: 83 Pickup Alternator Removal [Re: kyle-22r] #768580 11/30/06 03:03 AM
hunterp Offline
i can yank it quicker <img src="/forums/images/graemlins/lol.gif" alt="" />
you can weasel it out the top, you just have to get creative with the power steering lines.
its way easier that way imo
85 4runner/duals/detroits f&r/5.29s/winch/stuff
Re: 83 Pickup Alternator Removal [Re: hunterp] #768581 11/30/06 03:37 AM
P
parshal Offline OP
I can't seem to get it around the upper large hose from to the engine block. I might be able to drain the rad only a little bit and then remove that hose.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6057 MB (Peak: 0.6696 MB) Data Comp: Off Server Time: 2026-10-24 13:08:32 UTC
