drive shaft when lifting
#768587
11/30/06 03:22 AM
when i raise my sus. 3 inch do i have to fix the drive shaft issue or can i just leave it as is and get away with it.
Re: drive shaft when lifting
#768588
11/30/06 03:58 AM
Isuzu Moderator
Depends. If it vibrates after the lift, you will have to do something to address it.
Michael
[Re: mlclark]
#768589
11/30/06 04:18 AM
I have been running a year and a half with that vibration, including several wheeling trips, and about 10000 road miles. I have had no problems, other than a very loud knock on acceleration.
I would be glad to be rid of it, but i am fine with it the way it is. Eventually i will do something about it, but its not on the top of my list. -J <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
[Re: TrooperJ]
#768590
11/30/06 04:34 AM
Isuzu Moderator
It is not just the annoyance of the vibration or even the risk of grenading a u-joint on the road that I would be worried about (although, that is pretty high on my list). It is the expensive things that vibrating driveshaft is attached to, namely the transmission and the rear axle that I would be worried about. Vibrations will eventually take their toll on bearings and gears. I would rather spring for a few shims and new u-joints than have to work on the tranny or rear axle AND then fix the vibration.
Michael
[Re: mlclark]
#768591
11/30/06 04:41 AM
so all i need to get are some shims and new u joints thats it? i read that you need to get the shaft made longer or something like that if all i need are shims and u loints where can i get them. and where can i find the tool to crank up the torsion bars?
#768592
11/30/06 04:49 AM
Isuzu Moderator
People typically have a one-piece driveshaft made to eliminate the carrier bearings; as that is what tends to go out first. There are also degree shims that can be added to correct pinion angle after lift. The torsion bar cranking 'tool' is a 27mm socket and a breaker bar or impact wrench... and can be found anywhere that carries larger individual sockets. I got mine at the local NAPA; Sears carries them as well. Some people have used a 1 1/16" socket since its close in size and they already had one. The degree shims should be available through any 4x4 shop/wholesaler. www.independent4x.com has them.
Sean Strawmyer Back and ready to rock...... crawl. From Indiana or surrounding states and interested in wheelin'? Check out www.mwior.com
[Re: strawmyers]
#768593
11/30/06 05:42 PM
a 27mm socket...can be found anywhere that carries larger individual sockets. I got mine at the local NAPA; Sears carries them as well. Some people have used a 1 1/16" socket Check local pawn shops as well. I found a 1 1/16 for $0.50. It's not pretty, but it was cheap and it works. Jay
1991 Trooper - DEAD! 2.8 V6, 5 spd, 4WD, HD clutch, 2.25" exhaust, EPROM Chip, KC/Hella, Aisin hubs, Rancho 9000X's, Panasonic/Infinity/Alpine My Pics
