Damn Doors!!! #768601 11/30/06 03:30 AM
poorboy4x4 Offline OP
Just real quick! i recently purchased a set of 84 cj-7 for almost nothing! well all i needed according to ME, was some paddle handles and new key cylinders, well I got the key cylinders but i cant install the paddle handles, theres nothing to hold them in the door?! am I missing something?? please help! it's raining!
88 YJ, 4.2L, WEBER 32/36, On 33" Dunlop Mud Terrain, 4.10 ratio, tru-trac locker in dana 35...
Re: Damn Doors!!! [Re: poorboy4x4] #768602 11/30/06 03:33 AM
BobRowe Offline
What came in the doors when you got them?
Most paddle handles are in a square frame that mount in a square hole in the door metal. How is your door set up currently?
Re: Damn Doors!!! [Re: poorboy4x4] #768603 11/30/06 03:35 AM
BigJim Offline
Oh yes there is! There is a triangle shaped WEDGE holding them into the door... It can be a ***** getting them out too! But reinstalling them is a piece of cake.
Re: Damn Doors!!! [Re: BigJim] #768604 11/30/06 03:43 AM
the triangle pieces are ther but do i need to b end them out so it latches? or what? im almost ready to ribbet them in <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: Damn Doors!!! [Re: poorboy4x4] #768605 11/30/06 04:23 AM
BigJim Offline
IT IS SOMETHING i CANNOT EXPLAIN! iT SHOULD BE OBVIOUS TO SEE THE TAPERED END MUST back damn caps button out of it's place UP is the way I remember pushing it..
Re: Damn Doors!!! [Re: BigJim] #768606 11/30/06 04:34 AM
THe new door handles have the triangle wedges, but when i insert it there is alot of play? am i supposed to put something else in there to make them stay in place?? <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Damn Doors!!! [Re: poorboy4x4] #768607 11/30/06 05:28 AM
BigJim Offline
There is a rubber gasket that goes between the handle and the door. The wedge pressures against the gasket and stays in place forever.
Re: Damn Doors!!! [Re: BigJim] #768608 12/01/06 02:59 AM
thanks!
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6178 MB (Peak: 0.6958 MB) Data Comp: Off Server Time: 2026-10-25 22:22:47 UTC
