Rear parking brake cable? where to get one??? #768674 11/30/06 07:03 AM
G
Goose Offline OP
looking for the rear parking cable assembly. No one I know
carries them. And no one else makes it except for OEM.
I own a 1989, xtra cab pick up 2.6L 4x4.
Re: Rear parking brake cable? where to get one??? [Re: Goose] #768675 11/30/06 08:44 AM
mlclark Offline
Isuzu Moderator
There is your answer.
Call St Charles. www.stcharlesauto.com It will be the best price you can find.
Michael
Re: Rear parking brake cable? where to get one??? [Re: Goose] #768676 11/30/06 03:57 PM
W
Wayne Offline
I understand wanting a "cable in a kit"
I don't know what the cable looks like on the ends where it mounts up; there's probably some doo-dad clamped on that slides into a slot that you can't easily duplicate.
But if you've got both mounting ends, why not just go to home depot, get some cable and cable clamps, then tighten it down? (strip the insulation off where you clamp on). You could even throw in a turnbuckle and make it adjustable.
Then toss some paint or something on it if you're worried about rust.
It's not rocket science, it's not even automotive engineering science. It's a cable.
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: Rear parking brake cable? where to get one??? [Re: Wayne] #768677 12/01/06 03:24 PM
G
Goose Offline OP
I don't know what the cable looks like on the ends where itslides into a slot that you can't easily duplicate.
Wow now here is a good one!!! Thank you so very much.
Re: Rear parking brake cable? where to get one??? [Re: Goose] #768678 12/01/06 05:03 PM
Jim_Paget Offline
One of the ways in which our cables regularly fail is when water gets between the sheath and the cable itself. In that somewhat closed environment, the cable rusts and then the cable no longer moves. Similarly, water can get into the cable assembly and freeze. Similar result although temporary.
The initial failure point on these cables is often the rubber seals at the ends. Any home-built solution needs to address this issue.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Rear parking brake cable? where to get one??? [Re: Jim_Paget] #768679 12/01/06 05:36 PM
W
Wayne Offline
"That's what I get for thinking!" <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Rear parking brake cable? where to get one??? [Re: Wayne] #768680 12/02/06 03:11 AM
maxwell417 Offline
This fall I replaced the cables on both my Troopers. Got them from St Charles seems like the were about $50 each .... don't quote me. I try not to keep track of how much I spend on my Troopers <img src="/forums/images/graemlins/lol.gif" alt="" />
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Rear parking brake cable? where to get one??? [Re: Goose] #768681 12/02/06 02:00 PM
Billdo Offline
Jerry Lemond was able to get me one pretty cheap.
I will send you a PM with his e-mail address.
2000 Chevy Tahoe nothing special. 1990 Isuzu Amigo, 3" lift, 31x10.5x15 BFG All Terrain (Street), 33x12.5x15 (offroad), Pacesetter header, some ATM rash. More mods to come......
Re: Rear parking brake cable? where to get one??? [Re: Goose] #768682 12/02/06 05:15 PM
G
Goose Offline OP
thanks Jim it sounds like that is waht happen.
I guell oll keep looking for that cable and the cable sleeve.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6284 MB (Peak: 0.7320 MB) Data Comp: Off Server Time: 2026-06-07 09:06:49 UTC
