Bent rear axle shafts?!?! #768867 12/01/06 06:50 AM
CheviHemi Offline OP
So while i was out in the garage tonight working on getting my disc brake conversion to work (still doesnt)I noticed that the rotor was wobbling a little bit on the driver's side. I figured it was dirt and crud behind it so i pulled it off and wire wheeled the mounting surface which did not help the wobbling at all. After using a level to judge the amount of bent it is, there is about 1/16" of actual side to side motion. After all this i thought id check the other side as well...yup, same with that side. Has anyone ever had 2 bent axles?? I havent ever jumped this truck but I dont know about the PO. Could a bent rear housing make the shafts look like they are wobbling?
I am at a loss as to how this would happen!
Thanks!
Red 1996 S10 Zr2 (Semi-Retired Wheeler)
'84 Toyota on 36's (Project in the Making)
Re: Bent rear axle shafts?!?! [Re: CheviHemi] #768868 12/01/06 07:03 AM
kewlynx Offline
Do you know if the rear end has been apart at all?
You said 'PO'----leaves you wide open. <img src="/forums/images/graemlins/scared.gif" alt="" />
**ubi apis- ibi salus**
Re: Bent rear axle shafts?!?! [Re: kewlynx] #768869 12/01/06 07:05 AM
I put a different Third in it that was professionally installed, the bearings are new on the axles and there's no leaking gear lube.
Re: Bent rear axle shafts?!?! [Re: CheviHemi] #768870 12/01/06 07:08 AM
4Crawler Offline
Well, I have yet to see a straight rear axle shaft, I have 6 or so and all are bent to some degree or another. One drawback of the semi-floating design, the vehicle weight is cantilevered out past the single rear wheel bearing. And a bent housing should not make the axle wobble.
Re: Bent rear axle shafts?!?! [Re: 4Crawler] #768871 12/01/06 07:10 AM
so if its off by about 1/16" on the axle flange edge that wont make much difference? With a tire on it that would really multiply how much out of true it was and create vibes on the road. How much are they usually off on the ones that you have?
Re: Bent rear axle shafts?!?! [Re: CheviHemi] #768872 12/01/06 07:20 AM
kewlynx Offline
The runout spec is here:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/suspensionandaxle/33rearaxle.pdf
This is for a '93, but I don't think the older trucks' specs could be that much more different.
Re: Bent rear axle shafts?!?! [Re: kewlynx] #768873 12/01/06 07:22 AM
Ill check into those specs. From what I know of, the axles that I have in there are from the early 90's as well.
Thanks!
Re: Bent rear axle shafts?!?! [Re: kewlynx] #768874 12/01/06 07:25 AM
Yeah, im definatly way more than 0.2mm out of true like the spec says to be.
Re: Bent rear axle shafts?!?! [Re: CheviHemi] #768875 12/01/06 08:14 AM
kewlynx Offline
Bummer; see if any of these guys will check these before they send to you; currently at car-part:
1984 Axle Shaft
Toyota Truck LH Rr AXL, 4X4--U 9E04 $50 McNeilus Auto & Truck Parts USA-MN(Dodge-Center) Request_Quote 1-800-722-9318
1984 Axle Shaft
Toyota Truck RH Rr AXL, 4X4--U 9E04 $50 McNeilus Auto & Truck Parts USA-MN(Dodge-Center) Request_Quote 1-800-722-9318
1984 Axle Shaft
Toyota Truck RH Rr AXL, 4X4- 38687 $35 Viking Auto Salvage - QRP Partner USA-MN(Northfield) Request_Quote 1-800-657-4912
1984 Axle Shaft
Toyota Truck NOF $35 Dykes Auto Salvage USA-MN(Worthington) E-mail 1-800-658-2424
Re: Bent rear axle shafts?!?! [Re: kewlynx] #768876 12/01/06 08:21 AM
Hehe! That McNeilus place is practically in my back yard. I have the IFS housing so they wont work but I thought that was pretty cool that you found them there. I have spare shafts but ill have to get the backing plates pressed off and this last set cost me $70 to have done :S Might give the "Hate the Concrete" method a shot.
Thanks for your help!
~Eric
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6452 MB (Peak: 0.7656 MB) Data Comp: Off Server Time: 2026-06-07 05:45:11 UTC
