LSD failing? #768911 12/01/06 01:01 PM
A
anubis Offline OP
anyone had this. I know how the system works but over the last few months on any sharp turns I am getting a wheel to lock up and skid. Of course it is not extreme, only a small few chirps.
Just curious as to if this is a sign of failing or it all of a sudden decided to start working. I am trying to avoid regear as I am rebuilding a front axle that I want to swap in. If I regear the rear then I will lose out on 4 wheel drive for what little winter we have any more. thanks fellas
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: LSD failing? [Re: anubis] #768912 12/01/06 06:07 PM
BigSwede Offline
Does it do this while accelerating around a corner, or coasting? My LSD would chirp when I accelerated briskly around a corner, such as a right turn from a stop sign. That is nothing unusual. If it is doing it at other times...might be a problem there.
Serenity now!
Re: LSD failing? [Re: anubis] #768913 12/01/06 06:34 PM
Bansil Offline
This is typical for mine after about 30k
Change your fluid and add a tube of lsd additive,top off with fluid.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: LSD failing? [Re: Bansil] #768914 12/01/06 07:45 PM
A
anubis Offline OP
Thanks for the advise. It will have to wait a few weeks but It will be fine. I am in the process of moving and will finally have a 2 car garage. Just need to figure out how to get it in <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6015 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-06-10 01:41:58 UTC
