Page 1 of 3 1 2 3
Why Doesn't Indy4x Sell Ball Joint Spacers for 2nd Gen. Rodeo? #768915 12/01/06 04:26 PM
da_z_man Offline OP
Why doesn't Indy4x sell ball joint spacers for a 2nd Gen. Rodeo?
99 rodeo 2wd
3"body lift
3" suspension
Aussie Locker
PROCOMP ES-9000
Re: why dont indy4x sells ball joints spacers for 2 gen. rodeo [Re: da_z_man] #768916 12/01/06 04:49 PM
BigSwede Offline
Good question...why don't you ask him?
Also, sometimes he has new products that haven't made it onto his website...
Serenity now!
Re: why dont indy4x sells ball joints spacers for 2 gen. rodeo [Re: BigSwede] #768917 12/01/06 04:52 PM
Richard Saylor Offline
IIRC, flipping the ball joint on a 2nd Gen Rodeo causes the steering to over extend and pull out (or at least there seem to be a high probability of it). That's why there are no spacers made for it; because it's not recommended.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: why dont indy4x sells ball joints spacers for 2 gen. rodeo [Re: Richard Saylor] #768918 12/01/06 04:59 PM
da_z_man Offline OP
I'M NOT FLIPING ANY BALL JOINTS
99 rodeo 2wd
3"body lift
3" suspension
Aussie Locker
PROCOMP ES-9000
Re: why dont indy4x sells ball joints spacers for 2 gen. rodeo [Re: Richard Saylor] #768919 12/01/06 07:32 PM
holger Offline
it's not the case if you use OEM-length front shocks. The front downtravel is limited by the shocks. Unless you have longer shocks, your bottom point will be the same with BJ flipped.
Oleg
Deceased Rodeo'02 4WD.
Re: why dont indy4x sells ball joints spacers for 2 gen. rodeo [Re: da_z_man] #768920 12/01/06 07:35 PM
onebadtrooper Offline
Why whould you need the spacers if your not fliping the ball joints?? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: why dont indy4x sells ball joints spacers for 2 gen. rodeo [Re: onebadtrooper] #768921 12/01/06 09:33 PM
holger Offline
my understanding is that the spacers are useful (without BJ flip) when you are LOWERING your truck, to correct the angles. May be, the guy is in the low-rider truck business.
Oleg
Re: why dont indy4x sells ball joints spacers for 2 gen. rodeo [Re: holger] #768922 12/01/06 09:34 PM
Bigpoppax2 Offline
This is true somewhat, the front shocks do have a limited amount of travel. But, the true limiting factor of the front downtravel is a piece of metal that hit's the underside of the upper a-arm. Look or feel under it and you will find it.
From what I've read with hard use some people have bent this piece of metal and maybe then the shock will become the limiting factor.
Joe
Re: why dont indy4x sells ball joints spacers for 2 gen. rodeo [Re: onebadtrooper] #768923 12/01/06 09:43 PM
Smiley Offline
Then you don't need spacers.
The spacers are used to help correct the suspension geometry after doing a ball joint flip...
No flipà No spacers required.
And it's TRUE:
Flipping the ball joints is not recommended on 2nd Gen Rodeos & Passports.
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: why dont indy4x sells ball joints spacers for 2 gen. rodeo [Re: holger] #768924 12/01/06 09:45 PM
Smiley Offline
OK, that would make sense.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6425 MB (Peak: 0.7632 MB) Data Comp: Off Server Time: 2026-07-13 13:53:13 UTC
