Heater #769043 12/02/06 02:31 AM
A
AnthonyLocke Offline OP
hello, I have a 99' taco. The heater in it went out for no reason. I checked coolant levels. They're fine. I checked thermostat...it's fine. The heater fan works...it's just not hot air. I'm guessing it's the heater core....i just wanted to let you guys know before I take it in. I usually check all the inexpensive things out and troubleshoot beforehand. give me the knowledge....
<img src="/forums/images/graemlins/patriot.gif" alt="" />
94' YJ in the making...trail rig
Re: Heater [Re: AnthonyLocke] #769044 12/02/06 04:06 AM
kewlynx Offline
Hold up. There is a part called a BLOWER RESISTOR which is typically the culprit. Usually lives behind the blower fan.
Dealer-only part for around $25, or hit the local junkyards.
www.car-part.com
Also, a quick-n-dirty check on clogs in the radiator. Run vehicle up to operating temp. Shut off. Lightly touch fingers to radiator fins. Cool spots are clogs.
**ubi apis- ibi salus**
Re: Heater [Re: kewlynx] #769045 12/02/06 05:36 AM
A
is there any symptoms to actually check if it's the resistor?
Re: Heater [Re: AnthonyLocke] #769046 12/02/06 05:49 AM
kewlynx Offline
You already have a symptom. <img src="/forums/images/graemlins/pfft.gif" alt="" />
I *think* the resistance values are in the FSM sticky'd above. Not sure if the later rigs use the same one. I know the older trucks had 3 and 4 speed blower speeds, but your switch controls that, not the resistor.
You'd have to stick your nose under there to disconnect it anyway. <img src="/forums/images/graemlins/shame.gif" alt="" />
Re: Heater [Re: kewlynx] #769047 12/02/06 06:42 AM
A
if it's not the resistor than it's the core? tomorrow i'll start working on it. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Heater [Re: AnthonyLocke] #769048 12/02/06 07:31 AM
kewlynx Offline
Check the other stuff I told you to also. Cores ARE NOT CHEAP, and they're a beech to tear down to even get to them. Good luck and take your time.
Re: Heater [Re: kewlynx] #769049 12/02/06 08:27 AM
A
what does the resistor consist of? is it an electrical looking resistor?if it doesn't control the blower speed? what does it control?it's not in my shop manual.
Re: Heater [Re: AnthonyLocke] #769050 12/02/06 08:41 AM
kewlynx Offline
If you're looking at something that is NOT the FSM, you're NOT going to see it. That's why I pointed you to the one that's sticky'd.
www.4Crawler.com I think he's got a pic of one posted over there. Looks like toaster coils.
Re: Heater [Re: kewlynx] #769051 12/03/06 12:40 AM
L
lawnmowerman Offline
In the original post he says the heater fan works but no heat.If the fan did not work or more likley did not work on all speeds, I would suspect the resistor.No heat could be from a bad valve or it not opening due to a linkage issue.The heater valve is located on the firewall above the valve cover.The heater core being pluged up is another possiblity.
Re: Heater [Re: lawnmowerman] #769052 12/03/06 01:06 AM
A
I checked the inlet and the outlet hoses on the firewall....the valve isn't letting coolant passed. I already special orderd the part from the dealership. I'm going to try that before i replace the heater core. <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6382 MB (Peak: 0.7615 MB) Data Comp: Off Server Time: 2026-10-22 02:13:52 UTC
