What's the most likely cause?
#769163
12/03/06 02:13 AM
On this 22R, noticed a few drips of antifreeze comming from the header/pipe joint. Any thoughts/experience with this? This engine starts with no problem. I did change the oil awhile back and noticed it a strange lighter color, not the usual dark. Thanks for your input <img src="/forums/images/graemlins/smile.gif" alt="" />.
'80 4X4 Longbed
Re: What's the most likely cause?
[Re: Stevie]
#769164
12/03/06 04:03 AM
I hate to say it but it sounds like your headgasket is going..... Any white crud under the oil fill cap?
Jerod
89 4Runner, 282k miles. "I gotta have more cow bell"
[Re: 2ndGenToyotaFan]
#769165
12/03/06 04:13 AM
Any white crud under the oil fill cap? This does not always mean a HG is going. It happens on many vehicles that are not driven long distances. It is called condensation. An engine that is not allowed to run at full operating temperature for a while will build up condensation causing the white crud.
"Serenity through Sobriety"
[Re: OOP'S]
#769166
12/03/06 07:18 AM
Check the rear cover on the rear of the head, it is the egr passage and the gaskets sometimes fail. Do you see if the water ran down the firewall and dripped on the headers? Let me know.. Jeff S.
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6041 MB (Peak: 0.6599 MB) Data Comp: Off Server Time: 2026-11-19 23:56:16 UTCValid HTML 5 and Valid CSS
