What's the most likely cause? #769163 12/03/06 02:13 AM
Stevie Offline OP
On this 22R, noticed a few drips of antifreeze comming from the header/pipe joint. Any thoughts/experience with this? This engine starts with no problem. I did change the oil awhile back and noticed it a strange lighter color, not the usual dark.
Thanks for your input <img src="/forums/images/graemlins/smile.gif" alt="" />.
'80 4X4 Longbed
Re: What's the most likely cause? [Re: Stevie] #769164 12/03/06 04:03 AM
2ndGenToyotaFan Offline
I hate to say it but it sounds like your headgasket is going..... Any white crud under the oil fill cap?
Jerod
89 4Runner, 282k miles. "I gotta have more cow bell"
Re: What's the most likely cause? [Re: 2ndGenToyotaFan] #769165 12/03/06 04:13 AM
OOP'S Offline
This does not always mean a HG is going. It happens on many vehicles that are not driven long distances. It is called condensation. An engine that is not allowed to run at full operating temperature for a while will build up condensation causing the white crud.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: What's the most likely cause? [Re: OOP'S] #769166 12/03/06 07:18 AM
Jeffstoyo Offline
Check the rear cover on the rear of the head, it is the egr passage and the gaskets sometimes fail. Do you see if the water ran down the firewall and dripped on the headers?
Let me know..
Jeff S.
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6032 MB (Peak: 0.6590 MB) Data Comp: Off Server Time: 2026-05-29 22:41:37 UTC
