AGGH! (more) Timing Chain Woes.... #769382 12/03/06 10:36 PM
4WD22R Offline OP
Finally got a chance to fire the new motor up yesterday after finding my first day off in the past month (read: quit my job) :\ It ran, horribly, sounded like it was missing, not quite firing on all 4, tracked that problem down to a faulty spark plug wire, fixed that and attempted to fire her up again, the distro was adjusted all the way out so we decided to make sure it was at TDC, and restab the disto, which seemed to be WAY off. Put her back on #1 dropped it in but now it won't start <img src="/forums/images/graemlins/frown.gif" alt="" /> Cranks and cranks and backfires through the carb! Compression tested it and got 175-160-185-115. I've now pulled the valve cover off and am gettin down to adjusting the valves a little better, hoping that that'll take care of my compression problems. My biggest worry now though is when I pulled the valve cover off it looked like the cam was 180* off with the crank timing mark at 0* I rotated the crank 180* and the cam now looks to be in time, I thought I was at TDC before pulling the valve cover but it was late. I'm just praying that I didn't mangle any valves here, I did have some trouble lining the cam and crank up when the long block was going together, pretty sure it was all lined up correctly. A couple of main questions, is it possible that I have the cam in 180* upside down? I wouldn't think it'd even run that way :\ Second, when the crank is at 0* should the reference mark on the cam itself be right on top? see the first 2 pics smile mine is not cocked a little to the drivers side. Also could anyone tell me if the valves look okay for being at TDC? (3ed pic) Thanks a lot guys, this is my daily driver and the good will from my buddy is about to run out, I've been drivin' his car for a while <img src="/forums/images/graemlins/angry.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: AGGH! (more) Timing Chain Woes.... [Re: 4WD22R] #769383 12/03/06 10:39 PM
DRTDEVL Offline
The distributor is 180* out... When you re-stabbed it, you were at TDC for the crank, but not the cam.
The crank turns 2 times for every 1 cam revolution...
Re: AGGH! (more) Timing Chain Woes.... [Re: DRTDEVL] #769384 12/03/06 10:41 PM
4WD22R Offline OP
Thank you sir!
Hope Germany's treatin' ya well smile
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: AGGH! (more) Timing Chain Woes.... [Re: 4WD22R] #769385 12/04/06 02:16 AM
toyrunner Offline
Another thing to look at is the crank at TDC, cam pin should be 1200, not that reference mark you show. That will move the timing. The distributor should go in and the elongated hole for adjusting should have the bolt fairly in the middle of the adjustment.
Try that
Danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: AGGH! (more) Timing Chain Woes.... [Re: 4WD22R] #769386 12/04/06 04:27 AM
wsquaredodie Offline
Surprised that no one has keyed on the compression numbers you have. The 115 tells me you have a 1. bad head gasket 2. bad valve. 3. cracked head. Bad valve will give you pop back thru the intake if it is an intake valve...will give you exhaust farts if the exhaust.
trafdlo
Re: AGGH! (more) Timing Chain Woes.... [Re: wsquaredodie] #769387 12/04/06 04:36 AM
toyrunner Offline
New motor, may just be valve adjustment. Good call for an older been run motor <img src="/forums/images/graemlins/smile.gif" alt="" />
1985 SR5 4Runner
4.7:1 single case
Re: AGGH! (more) Timing Chain Woes.... [Re: toyrunner] #769388 12/04/06 07:11 AM
4WD22R Offline OP
That's what I'm prayin' for! adjusted the valves and moved the cam back a bit, got her timed up and it runs like a champ now! Gonna put some miles on it and give those valves another look after those rings seat I'll hit it with the compression gauge again. Thanks a lot guys!
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6218 MB (Peak: 0.7141 MB) Data Comp: Off Server Time: 2026-07-09 16:05:11 UTC
