Page 2 of 3 1 2 3
Re: SAS options? [Re: StockRaider] #1000043 06/14/10 11:55 PM
LandRaider Offline
I am not sure of how much lift I would do, but the engine and drive train I really don't want to modify. I remember reading where LandRaider said the IFS actually weighs more than a Solid axle setup? I mean a little weight loss is always a welcome side effect.
Enghhh..... I dunno about that. I don't remember for sure the weights, and do not remember saying that, but I could have.
It's Prob close, BUT you have to remember... live axles are 100% unsprung weight. It's irrelevant really.
Re: SAS options? [Re: FatTony] #1000044 06/15/10 12:00 AM
Angelo Offline
I know Isuzu has some independent shops that support them. They could possibly have some kits that would adapt to ours very closely I would imagine. The Trooper is VERY similar to the Montero, through out all the Generations. I'm interested in hearing more about the Nissan kits too.
And what about Dodge Ram axles?
Re: SAS options? [Re: Angelo] #1000045 06/15/10 12:16 AM
StockRaider Offline OP
How is the ride? Driving my dads Ram1500 with a solid front axle always feels a little more unforgiving on the bumps. Definitely not a deal breaker being that the Raider isn't my DD anymore.
So, the Wagoneer axle is the best JY option? Also, did any models have a matching gear ratio for our trucks? Or do are they all going to have to be swapped to match?
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: SAS options? [Re: Angelo] #1000046 06/15/10 12:16 AM
LandRaider Offline
They'll work just fine. You'll just have the tires completely outside the fender wells.
Re: SAS options? [Re: Angelo] #1000047 06/15/10 12:18 AM
0778drz110 Offline
Dodge ram axles have CAD 4wd crap to mess with IIRC And you never see someone swapping them in so something must suck about them...I just haven't looked into it. (EDIT: I'm talking about mid90s trucks, older ones are good)
Troopers are passenger drop so they aren't that close, but if you could get a isuzu SAS kit to fit a waggy axle than that would be great.
I looked last night into the nissan kits for a few minutes, the only one I saw was a bolt on kit and almost all of it would be useless for a montero IMO.
I think the biggest factors is the fab work, finding an axle, time, and $$...
I was going to swap but since its my daily driver I couldn't find the time.
Re: SAS options? [Re: 0778drz110] #1000048 06/15/10 02:07 AM
torquemonster Offline
Are there many peope that have a GEN II SAS?? just trying to think of it, I don't recall reading anything or seeing any pictures on here. By the way it seems I will have my pajero for all eternity, so once it isn't my daily driver I'd tackle a project like that. Being Right-hand drive might make it a bit more interesting though <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: SAS options? [Re: torquemonster] #1000049 06/15/10 04:20 AM
0778drz110 Offline
A few in Australia have, I can't think of any in the states though.
Re: SAS options? [Re: 0778drz110] #1000050 06/15/10 08:35 AM
A lot of nissan guys down here have SAS'd thier trucks using waggy axles, and i've looked them over a bit. What i meant when i said the nissan kit would work was it uses the driver drop waggy axle and it has all the mounts and linkages you'd need, i didn't mean it would just slap right on. You'd likely have to make a crossmember or two but that's kid stuff.
Re: SAS options? [Re: TOASTY] #1000051 06/15/10 10:37 AM
LandRaider Offline
If I made a weld on SAS kit for waggy axles, would people buy it?
Re: SAS options? [Re: LandRaider] #1000052 06/15/10 10:41 AM
LandRaider Offline
Hell.. I will just make measurements, to where my sprng eye's are now, and make you a template out of posterboard, and you can get some steel, and make it socket up on the frame, and bolt to existing holes, to make it bolt on up front, and maybe just weld the rears.
What do you think toasty?
Bolt on crossmember up front to existing frame holes, Bolt on shock mounts....drill your own holes, and bolt on rear spring mounts? drill you own holes??
Or locate it with existing holes, and weld it in???
This would take out the fab work, and just require basic welding skills.
I'd guess it'd cost 5-6-700 bux. You'd still have to buy a driveshaft, steering linkages, axle, springs, etc.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6489 MB (Peak: 0.7554 MB) Data Comp: Off Server Time: 2026-11-04 19:54:33 UTC
