Re: Snowplow for a 1989 2-Door, 3L, V6 Dodge Raider? [Re: LiveLife] #1000116 06/21/10 05:09 AM
djacidjac Offline
I found a 6-foot plow setup complete, that came off of a CJ5 jeep. I thought it was a Meyer, at least the pump is. The frame rails seem to be the same width on the Raider as a CJ5 and there are plenty of weld nuts to attach it to. I had to modify (shorten and re-weld) the push frame and weld 2 "tabs" onto the tubular cross member. I believe you could use u-bolts and a plate if you can't weld to the vehicle. If you're by yourself, I'd recommend one of the newer plow hookups that self-align and "click" on and off. Maybe you could have someone fab adapters. Also, get power angle (all the new stuff is anyway.) I'm working on mine soon. I'm going to take pictures.
http://www.facebook.com/photo.php?pid=708526&l=3c8bd582de&id=1616543971
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Re: Snowplow for a 1989 2-Door, 3L, V6 Dodge Raider? [Re: LandRaider] #1000117 06/27/10 05:59 AM
L
LiveLife Offline OP
Greetings, folks!
I really appreciate your inputs on the snowplow. I will have to look around for something used because the cost of a Meyer is just way too high for me. I want (i.e. ôcan affordö) as simple a plow as possible, i.e. a bolt-on plow blade and nothing more.
Is there anything that you need that we could help you with?
Well, a winning lottery ticket would be great! Then I wouldnÆt be ôon vacationö anymore. (Honestly, it hasnÆt been much of a vacation . . . But thanks for asking; IÆll share the winnings!!)
X-)
A (slightly) unrelated question:
It was noted [color:"blue"]HERE[/color]: ôThe crank bolt on ALL Mitsubishi 3.0L V6 engines is a recall item.ö
I have not found any verification of any such ôrecall item,ö which I understand to be something that Mitsubishi/Dodge will pay to have done. I never got any such notification, nor can I find any online, and I couldnÆt find any definitive answers in the 4x4wire archives, just a lot of warnings. [color:"blue"]HERE[/color] is a page listing recalls and it is not mentioned.
Any advice would be appreciated! (ÆBecca has 98K miles on her.)
Blessings and THANK YOU!
1989 Raider (stock), SWB, V6, M/T, 111K Miles
- Front: 32x11.5-R15, Super Swamper TSL SXs
- Rear: 33x10.5-15LT Super Swamper Boggers
Re: Snowplow for a 1989 2-Door, 3L, V6 Dodge Raider? [Re: LiveLife] #1000118 06/27/10 02:49 PM
MarkG Offline
IIRC Mitsubishi didn't recall the crank bolts on the 1989 models. They issued the recall for a later year. Even though they used the identical crank bolt in 1989. So, even though Mitsubishi never issued a formal recall for the 1989 crank bolts, it's best to replace them with the newer style.
Re: Snowplow for a 1989 2-Door, 3L, V6 Dodge Raider? [Re: MarkG] #1000119 06/27/10 11:15 PM
hazy_daze Offline
I have new spares. If you'll PM an address where you can receive it, I'll mail it to you at no cost...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6113 MB (Peak: 0.6691 MB) Data Comp: Off Server Time: 2026-06-07 01:56:16 UTC
