Page 2 of 6 1 2 3 4 5 6
Re: starion motor [Re: runningbird] #1000459 07/10/10 06:40 PM
runningbird Offline OP
Just a follow up to where we are at with our conversion.
My son and I went up north to pick up the motor and EVERYTHING that goes with it. David did a great job of pulling and keeping things nice...Acually once I saw the car I felt kinda bad, It was a real nice car. But I only needed the motor.
I got everything home and have just been cleaning and organizing. lots of wires, My son will be a huge help to me on this. It will be a few weeks till I move forward with this because of work and such. Will keep everyone posted on progress though!
87 raider starion motor in, looking for an auto trans.
Re: starion motor [Re: runningbird] #1000460 07/10/10 10:27 PM
Nice and clean. Go, Man, go.
Re: starion motor [Re: JohnnyBfromPeoria] #1000461 07/11/10 12:28 AM
A
airbats801 Offline
that starion engine is waaay to clean. something must be wrong with it lol j/k
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: starion motor [Re: airbats801] #1000462 07/11/10 02:46 PM
one thing that will hold me up a bit is, the flywheel off the starion does not match our torque converter. 4 bolts on the starion, 6 on the raider. Our original flywheel was unrepairable. So does any one know, can I just have new holes drilled in the starion flywheel to match our torque converter. I do understand that they would need to be precise in there location.
thanks!
Re: starion motor [Re: runningbird] #1000463 07/11/10 04:08 PM
Kevin C Offline
The Torque converter pilots on the the crankshaft. That said the location of the holes in the flexplate is not as critical since the dont center the converter. They do have to line up so you can get the bolts in and be accurate located so that they load up on the converter bolts evenly when transmitting torque.
Also the term for the part that I would use is flexplate.
Kevin
Re: starion motor [Re: Kevin C] #1000464 07/11/10 08:50 PM
haztoys Offline
Sorry on not getting back to you Mark ...Motor looks great hope it get good uses for you ...
Don't drill the flexplate ..Get the right one ...Theres one up here if you need it its on the Monty so you would have to get it out .. Do some looking take your time ...
Let me know ..
David
Hazardous Toys inc
Re: starion motor [Re: haztoys] #1000465 07/11/10 09:10 PM
david
I sent you a pm.
Re: starion motor [Re: runningbird] #1000466 09/17/10 12:17 AM
well after a long delay we are back at it. we got the harness in place today and I am preping the motor. My question is how do we extend the oil pickup....do we have and extension welded on?
thanks
Mark
Re: starion motor [Re: runningbird] #1000467 09/17/10 02:55 AM
plh Offline
I am putting a Montero Oil Pan, Pump and Oil pick-up on my starion swap.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: starion motor [Re: plh] #1000468 09/17/10 03:50 AM
on our starion motor the existing pickup seems to come of the pump internaly. there is a place to put on the Raider pickup but what to do with the existing pickup and hole it would leave? I have the pan and pickup from our raider but I was expecting that the pickup was originating in the same location but that is not the case.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6413 MB (Peak: 0.7496 MB) Data Comp: Off Server Time: 2026-06-07 11:33:43 UTC
