Re: starion motor
[Re: fasteddy]
#1000499
10/13/10 12:30 AM
ok thanks for the help, now could one of you tell me how do I get that bushing out, and do I take the one out of the raider motor and put it in the starion motor? again thanks!
87 raider starion motor in, looking for an auto trans.
Re: starion motor
[Re: runningbird]
#1000500
10/13/10 12:50 AM
you need a steel rod the diameter of the inside diam. of the bushing. Pack the bushing cavity with grease, and drive the rod into the grease. The hydraulic pressure will force the bushing out. Or a cold chisel and a hammer...
Re: starion motor
[Re: fasteddy]
#1000501
10/13/10 03:15 PM
Re: starion motor
[Re: fasteddy]
#1000502
10/15/10 12:53 AM
got the bushing out and the spacer and driveplate on. I'll put the motor in tomorrow.
Re: starion motor
[Re: runningbird]
#1000503
10/15/10 01:08 AM
Nice <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: starion motor
[Re: OldColt]
#1000504
10/15/10 11:39 PM
Re: starion motor
[Re: runningbird]
#1000505
10/16/10 12:10 AM
You would be best to convert the PS pump to a remote reservoir.
Re: starion motor
[Re: OldColt]
#1000506
10/16/10 04:57 AM
and convert the worthless stock OPG to a mech gauge, which will eliminate the fatso sender. and you can move the OPG sender to the oil cooler adapter - there's a plug there same size hole, and move the plug to the original position.
Re: starion motor
[Re: fasteddy]
#1000507
10/17/10 03:10 PM
so I had a chance to look things over a little. In the last picture there is a plug where the sending unit is on the raider motor. I was thinking about taking that out, putting the sending unit in there and plugging the starion sending unit spot.
this may be what you are talking about?
anyway, won't have much time next week due to life but will get on it when I can.
Thanks for the help.
Re: starion motor
[Re: runningbird]
#1000508
10/17/10 11:26 PM
Yes. I plead senior moment. The reservoir for the ps pump will hit the sender if the sender is at the cooler adapter, so you move it to the plugged location as you describe. Both are in the full pressure path from the pump in the main gallery...
