1990 4runner with a loose tranny output shaft #1001691 06/30/10 04:28 AM
xrtim Offline OP
I've got a vibration at about 65 mph, doesn't matter if I'm coasting or on the gas. I can grab the driveshaft right where it comes out of the tranny and can wiggle it a bit. The whole output shaft moves a bit. I checked a buddys truck his is tight. Question is, how do I tighten it? And, is it the likely problem? thanks... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 1990 4runner with a loose tranny output shaft [Re: xrtim] #1001692 07/01/10 10:41 PM
Adam F Offline
Could be a worn out bearing, could just be a loose flange nut.
Grab a 30mm socket, and either an impact or a breaker bar. Remove the 4 driveshaft bolts (2 14mm wrenchs) and you will see the flange nut.
97 4R, stock, daily driver
Re: 1990 4runner with a loose tranny output shaft [Re: Adam F] #1001693 07/15/10 11:12 AM
PepCoco Offline
I did exactly that. it helped alot, is the front setup the same.?
ROCK & ROLL OVER IT! THATS WHAT I SAY!
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5924 MB (Peak: 0.6458 MB) Data Comp: Off Server Time: 2026-07-15 12:43:05 UTC
