Page 1 of 8 1 2 3 4 5 6 7 8
87 swb 2.6 turbo swap #1001860 07/01/10 09:58 AM
A
airbats801 Offline OP
Snagged a cheap one today not running. 87 raider gold auto lsd and headlight squirters plsu bouncy seat smile.
Engine seems seized possibly do to rust from a cracked head or spun bearing. I'll probably pop the head off it tomorrow and see whats up. If worse comes to worse I have a turbo engine sitting around. I might run it na for a bit.
before I decide to turbo. I didnt want a auto but this was the only decent deal around and I liked the color.
I'll probably 5 speed it with the trans I have, or get it running then sell it then buy a 5 speed as I dont really care for doing 5 speed swaps in mitsubishi's. Most likely I will just 5 speed this though.
First plan is to get it driving again.
I already have a sr air locker with weld on perches ready to swap in. I figure once its driving I will 5 speed it and hopefully sell off the auto stuff. A v6 front setup will come laterl with lsd for the time being until work picks back up in the fall at that point I will go for a aus locker up front. I'm giong to shoot for some older enkei 15inch with 33s. Oh and of course turbo swap.
Here are some crappy cl pics. Should have some ebtter pics up once I wash it and get hear cleaned up. It's been sitting since 2003.
I'm going to go pickup the rest of the 5 speed parts I dont have tomorrow at the jyard. My list so far since i already have a complete trans is as follows
-clutch pedal, brake pedal
-master n slave + line
-front driveshaft
-rear driveshaft I assume the length is different from the 5 speed and I know the slide yoke is different
-center console boot area
Anyone know if the auto crossmember n manual crossmember bolt into the same location?
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: Picked up my first swb [Re: airbats801] #1001861 07/01/10 12:48 PM
The crossmembers bolt in the same location, the auto has a rearward extension for the mount.
Re: Picked up my first swb [Re: OldColt] #1001862 07/01/10 01:36 PM
haztoys Offline
Cool fined ..Good to see another find its way back running ..
Now make it run ...And sell it to someone who wants a auto Monty ... I'm a 5 speed man too.. But theres anuff 5 speeds out there ..Know need to cut up a auto truck when so many are look for one ...
As me being a 5 speed man too ..I have all the parts and sub assimblies for my Raider ready to drop in for my new "Gravel Raider "..... But the Raiders and auto and I'm still toying if I like it as an auto trans ...(Still can't get the sucker to turn at speed with the auto trans..???.. <img src="/forums/images/graemlins/confused.gif" alt="" />.... <img src="/forums/images/graemlins/scared.gif" alt="" />...Maddning ..lol...)..So I may see if someone would trade for a 5 speed or sell it out right ... So I'm just fixing her back to good running stock for now ..If I dont want my auto Raider I realy need to get it to someone who does .
Trans swaps are to big a pain in my book ...
Its up to you ...Peace..
Have a good day
David
Hazardous Toys inc
Re: Picked up my first swb [Re: haztoys] #1001863 07/01/10 02:29 PM
A
YEah they are a real pain. I've done 3 in random mitsu and they are never very fun since mitsu seems to use diff firewalls, or at least doesnt punch the holes ofr the master and diff tunnels ie starion.
Re: Picked up my first swb [Re: airbats801] #1001864 07/01/10 02:52 PM
MainstreaM Offline
Wish you guys were on this side of the country. I've been wanting to go auto. Nice find.
Kane
89 Conquest - 2.4 DOHC <--Thats right DOHC Turbo and MPI.
87 Starion flatsider - under restoration
87 Conquest - Saved from the crusher
86 Conquest - Another crusher rescue
88 Conquest - Previous owner abandoned project
87 Raider - under construction
86 Conquest - DD
Re: Picked up my first swb [Re: MainstreaM] #1001865 07/02/10 06:40 AM
I've read the automatic is more suitable for a turbo than the 5-speed. I've passed on some auto swbs because of the increased gutlessness. However...
Re: Picked up my first swb [Re: rxinhed] #1001866 07/02/10 08:56 AM
A
they are, but I figure I can get some life out of this 100k trans I have and then swap in the starion guts into one downt he road.
Re: Picked up my first swb [Re: airbats801] #1001867 07/09/10 08:17 AM
A
I picked up some wheels n tires today. Got a good deal even though they are a little bigger than I wanted to go. enkei 15x10 with 33 12.5 tires. Not much of a mudding tread but should be ok for putting around trails n sand and what not. I'll get some pictures of them mounted tomorrow when if igure out where the hell I put my jack handle.
I did a little work on the engine today. heads ready to come off, but I had to go get those wheels so I never got around to it. It's beem around 100 degrees out and it's not real fun to work in the tiny apartment garage.
I tried turning the engine over with my proto brreaker bar and a big sleaver to no avail other than tightening the crank bolt. This is after I sprayed a ton of kroil in the cylinders. I'm guessing either bearings are seized up, or allt he cylinders are rusted big time. Hopefully its just cylinders, but eh. I'll find out tomorrow. if the engine is toast, I will probably just turbo it. I have a turbo engine I picked up the other day along wit a few wiring harness's laying around. I might toss on a weber 32/36 with the turbo block for the time being just so I can move it around as I dont have a spare turbvo and money is tight.
Re: Picked up my first swb [Re: airbats801] #1001868 07/09/10 10:14 AM
It would not surprise me that someone ignored the rattling noise from a non adjusted secondary chain till it wore the teeth off and lost oil pressure. The bottom end tightens up pretty quick then.
Re: Picked up my first swb [Re: OldColt] #1001869 07/09/10 11:25 AM
A
yeah who knows. Looks like ther was antifreeze on 2 and 3 plugs, and the papers she gaveme says they did timing and bearings at one point, but then there is a deal that says power punch so it's probably crap.
Would a 88 auto starion torque converter be any better tan the stock 87 raider converter?
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6475 MB (Peak: 0.7707 MB) Data Comp: Off Server Time: 2026-11-15 10:18:06 UTC
