Page 6 of 8 1 2 3 4 5 6 7 8
Re: Picked up my first swb [Re: MontyMcV] #1001910 09/26/10 08:11 AM
A
airbats801 Offline OP
Maybe I shouldnt clean that valve cover. It's straight up legit a Cash For Clunkers valve cover.
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: Picked up my first swb [Re: MontyMcV] #1001911 09/26/10 01:13 PM
JAVYPRO Offline
I am not that far behind on my setup, its just that time has become more scarse. That plus I am still in need of some much needed parts as ECU, TBI, harness and knock box. Besides that I am loving your progress <img src="/forums/images/graemlins/kewl.gif" alt="" />
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Picked up my first swb [Re: JAVYPRO] #1001912 09/26/10 01:40 PM
plh Offline
Javy
Javy,
PM me. I have the parts you are looking for. They are also listed in the Garages Sales section. Open to offers. Thanks
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Picked up my first swb [Re: plh] #1001913 09/26/10 03:06 PM
JAVYPRO Offline
YOU ARE THE MAN!!!
Pm sent.
Javy
Re: Picked up my first swb [Re: airbats801] #1001914 09/28/10 09:43 AM
A
slowly getting some stuff done, I took a break the last few days. I about have the fuel pump mounting situation figured out. I'm not sure if I want to mount it on that crossbar between the tank and axle though. Not sure if I will have any issues if I go sinking the rig in deap mud or water.
I somehow forgot the damn heater core line for the engine before I put the head on, so I had to work that piece in, not very fun.
I also found my torque wrench and torqued the head down.
I have to go buy a bunch of random stuff tomorrow. I wanan get some ford 4.6l injector clips, a few mroe hose clamps, clutch slave cylinder, and wire for the ecu and fuel pump power.
I'm also waiting for my turbo and oil cooler lines to come in. I'm hoping to get the wiring harness installed tomorrow, along with the power steering pumjp with a mod, fuel pump, and whatever else I can do while I am waiting for parts. I may get the radiator installed.
Re: Picked up my first swb [Re: airbats801] #1001915 09/28/10 01:48 PM
I used a Starion pump and attached it to the crossmember as you are considering. It has been there for 21 years now with no problems. Mine has spent hours submerged and worse than that the last 13 years parked over tall grass with our moist acidic soils.
Re: Picked up my first swb [Re: OldColt] #1001916 11/03/10 06:08 AM
A
I haven't updated this in quite some time.I have pics n what not to upload but not right now.
This is basically what I need to drive it.
turbo bolt for vband
clutch slave
ps resivoir with pump mount off starion
fuel pump block off plate
pcv line
A bunch of small stupid [censored]. It will be running next week. I'm stuck in welding classes this week.
Re: Picked up my first swb [Re: airbats801] #1001917 11/28/10 03:05 PM
A
I should update this. I'm about to finish off my 6'th pounder of coors. Harness is mostly ran end plugged in. Radiator hooked up, valves adjusted, turbo cam installed, thermostat installed, test fitting the air filter looks good, coil hooked up, and I managed to use the wrong mail b38 connector for my 88 harness lol. It's getting hard wired now.
I should have the downpipe on tomorrow along with a new water line for the turbo return, fue;l return lines installed, and fuel pumpe wiring hooked up.
I\m pretty sure I'm real close. I need to make sure the tank has been drained, but there isnt much left.
crappy iphone pics yes!
I had to install a proper grill
Manual hubs and new wheel studs will be going on soon.
Re: Picked up my first swb [Re: airbats801] #1001918 11/28/10 06:35 PM
socal1200r Offline
Kudos to you for going thru with your conversion. I'm giving up on mine, so I'll have to get rid of the turbo conversion parts I've accumulated so far (turbo, manifold, custom downpipe, hoses, intercooler, front engine cover, t-stat cover, water pump, basically everything except the fuel side, oil cooler, and electronics).
Despite what folks have said, I'm not convinced this is something a shadetree mechanic can do, so I'm not going to test my patience. I'm going to cut my losses and just drive it with the new Weber.
1989 Monty SWB, 2.6L w/MT, 15" alloys, 265/75 Dunlop Radial rovers, rear air shocks, Weber 32/36, SQ oil cooler, (SOLD Oct 2012)
Southeast VA, USA
Re: Picked up my first swb [Re: socal1200r] #1001919 11/28/10 07:44 PM
Kevin C Offline
When I lived in California I had an apartment with no place to work on a car.... My First Turbo Raider was totaled so I built one in the parking lot at my work place, under a big palm tree.
One member built one while in school, If I'm not mistaken from his dorm room.
This may not be for everybody, but quite a few have done swaps with limited resources.
The only issue I had was when the VP of the company found me using the company fork lift for an engine hoist. The upside was I was licensed to run it. It saved me a trip to the local rental company. He scowled at first... then smiled and went on his way.
A lot of this has to do with comfort level and work VS reward. For a small investment you can get your 2.6 running with a new carb. The commitment to do a turbo swap is a lot bigger in cost and labor.
Kevin
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6524 MB (Peak: 0.7589 MB) Data Comp: Off Server Time: 2026-11-16 08:55:44 UTC
