Re: Rocker panel armor is on. (pics to come soon)
[Re: off-roader]
#1002837
07/13/10 07:25 PM
John who?
Looks great......The welds look fine. <img src="/forums/images/graemlins/cheers.gif" alt="" />
96 Montero LS 24V DOHC 3.0L. 98 Montero 24v SOHC 3.5L, factory rear locker, Winter/tow package. 63 Jaguar XKE 3.8L FHC 2000 Mercedes-Benz e430 07 fj cruiser
[Re: cmonty72]
#1002838
07/13/10 07:36 PM
John's my brother in law. He's the guy in the pics. I was doing the shooting. <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: cmonty72]
#1002839
07/14/10 01:28 AM
Looks great......The welds look fine. <img src="/forums/images/graemlins/cheers.gif" alt="" /> That's funny... I noticed that most of you that are commenting are from commiefornia. So, I guess I should have put my Rainbows and Skittles gloves on for you bitches. Those welds are horrible. They might hold. If those were pics of a trail fix, good work. Its not. All of that Pretty and/or functional weld comments are excuses for a bad welder. A "GOOD" weld looks "PRETTY" because it is a proper weld. Initially, the point I was making was that on critical welds, maybe you should have an competent welder do the work. If your learning or whatever,then fine,but at least practice before you weld on your frame. What do you think the golden state bridge is held together with, besides rivets and bolts? Unicorn piss? NO! Good and "pretty welds".
Hard Times Don't Last... Hard People Do...
[Re: blueeyeddevil]
#1002840
07/14/10 04:24 AM
The guy you quoted isnt from "commiefornia" Just sayin...
You could really make a good point here but you really came across like an <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> hat with that last comment.
commiefornia? really? <img src="/forums/images/graemlins/lol.gif" alt="" />
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: blueeyeddevil]
#1002841
07/14/10 05:02 AM
Looks great......The welds look fine. <img src="/forums/images/graemlins/cheers.gif" alt="" /> That's funny... I noticed that most of you that are commenting are from commiefornia. So, I guess I should have put my Rainbows and Skittles gloves on for you bitches. Those welds are horrible. They might hold. If those were pics of a trail fix, good work. Its not. All of that Pretty and/or functional weld comments are excuses for a bad welder. A "GOOD" weld looks "PRETTY" because it is a proper weld. Initially, the point I was making was that on critical welds, maybe you should have an competent welder do the work. If your learning or whatever,then fine,but at least practice before you weld on your frame. What do you think the golden state bridge is held together with, besides rivets and bolts? Unicorn piss? NO! Good and "pretty welds". Lol, wow! Every time I see someone resort to insults in a discussion versus facts I usually come to the conclusion that their either simply ignorant & lacking in their communication skills, a child who hasn't learned how to have an adult discussion, or wrong. Also this kind of behavIor isn't tolerated on these forums especially when we don't know you from Adam (not you toasty <img src="/forums/images/graemlins/wink.gif" alt="" />). So either post up something informative and constructive, or don't post. So, r u saying the weld don't look good and because of that they won't hold up? Can you support this with anything other than insults? I see from your profile that your a fabricator after all.... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
[Re: blueeyeddevil]
#1002842
07/14/10 02:50 PM
What do you think the golden state bridge is held together with, besides rivets and bolts? Unicorn piss? NO! Good and "pretty welds". It's the Golden GATE Bridge, but I would have to agree with you a little on the welds. First off I could NOT have done a better job, but when the welds pool upwards and are not flat they don't have great penetration. It is by no means a terrible job, but after some use the sliders may bend up a bit. Ask me how I know. <img src="/forums/images/graemlins/notooth.gif" alt="" /> EDIT: In looking back at the pics it looks like those plates are pretty thick, so I am guessing he made multiple passes which is why they look pudgy. All in all I would say it definitely is functional.
1990 Montero LWB 3.0 Lodi, Ca. USA
[Re: blueeyeddevil]
#1002843
07/14/10 07:15 PM
You're obviously new here, so here is your warning. I strongly suggest you take it seriously. Language like this will not be tolerated. Period. While the quality of work may be in question, there is no need to speak like this to anyone here. EVER.
[Re: LandRaider]
#1002844
07/14/10 08:28 PM
Welds look a bit sloppy but prob will hold up. None the less I would definitely add some bracing. Having a guy standing on rock rail is bemusing but doesn't tell much. Put a Highlift or something under it for more real world test. If there are any concern doing it then its not a real world rock rail because when you need them they will exposed to likely much higher loads. I would specifically concentrate on either/both ends since that would expose mounting arms to highest stress. In real world we don't always get hang up smack in the middle. Do we? <img src="/forums/images/graemlins/cheers.gif" alt="" />
92 SR, 285/75R16 Yoko MT ARB locker GAST compressor AirLift 1000 MM10500 Snorkel custom rear bumper 02 Montero LS died protecting the master 08 PowerWagon (stock!)
[Re: Alex Kogan]
#1002845
07/14/10 08:53 PM
I like the wheels. <img src="/forums/images/graemlins/smile.gif" alt="" /> The question I have is why is the bracket the frame sticking up from the top of the frame? the good thing is if you are consern about the welds there is enough space between the welds to add more.
[Re: RECON45]
#1002846
07/14/10 09:04 PM
Thanks to all the rest of you for the advice without the attitude. We did do a hi-lift test in the middle and on each end & it seemed to hold up fine. We also both jumped up and down on them to be sure since we both weighed in at close to 1 ton <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />. Seriously though, the question I'm hoping to answer soon is whether or not it will hold up on the trail and only way to truly know that is go for a run. I like the wheels. <img src="/forums/images/graemlins/smile.gif" alt="" /> The question I have is why is the bracket the frame sticking up from the top of the frame? the good thing is if you are consern about the welds there is enough space between the welds to add more. Yeah, those wheels have been with me since my 2nd Montero (since the vmag days back in the 90's <img src="/forums/images/graemlins/zombie.gif" alt="" />). As for the brackets sticking up above the frame rails... they were purchased from Trail-Gear and came that way (L-shaped) along with some right angle gussets. Rather than spend time cutting the pieces I wouldn't need off (since my install wasn't going to be a simple one) we installed them that way instead. <img src="/forums/images/graemlins/kewl.gif" alt="" />
