Off-Roader's 96SR Update: Rocker panel armor is on. (pics are now up!)
#1002827
07/12/10 05:46 PM
As some of you know, I purchased the Trail Gear rock sliders to mount up on my rig quite some time ago. Finally got around to mounting them this sunday.
I started by first removing the coating of oil/grease that came with them. This grease prevents oxidation. Removal was extremely easy using Lacquer thinner soaked paper towels. To protect my skin, I wore nitrile gloves. I highly recommend the thinner to anyone who needs to remove grease from metal.
Next we positioned the sliders on the rig by simply using standard jack stands & when necessary excess metal stock to fine tune the fit.
Next we cut the legs to the right size. Since the sliders were mounted higher than the frame, we had to cut the legs at an angle using a horizontal pivoting band saw. While I didn't need to adjust the angle if you were a little bit off, you could easily grind it down to fit.
For the 2 rear legs (or four if you're counting both sides), it was a simple angle cut.
For the 2 forward legs, we had to extend the mounting tubes and cut a compound angle (2 angles on 2 axis) which was an interesting process on that saw. In the end we got the angles right by using a grinder to fine tune them.
I have pics and will post them up later this evening once I have time to go through them.
Re: Rocker panel armor is on. (pics to come soon)
[Re: off-roader]
#1002828
07/13/10 02:24 AM
Who has the graphic...???
[i][b][This thread is useless without pics.]
[Re: MontyMcV]
#1002829
07/13/10 07:21 AM
Positioning driver side rock skid using 4 jack stands and misc. spacing materials (see steel rod on rear outer jack stand). ![[Linked Image]](http://inlinethumb38.webshots.com/47269/2066944700104986527S600x600Q85.jpg) Tacking on the optional backing plates I bought with the rock skids. Notice the cleanly ground frame area just where the welding bead will be. ![[Linked Image]](http://inlinethumb15.webshots.com/43342/2901874140104986527S600x600Q85.jpg) While John was mounting those plates, I busied myself cutting the mounting bars to fit. The rear bars were a simply angle ~12* IIRC. ![[Linked Image]](http://inlinethumb20.webshots.com/47443/2892635400104986527S600x600Q85.jpg) The front bar was a compound angle due to the added angle of the frame going inwards. Those were also cut on the saw but held by hand instead of simply being clamped into place. John tacking the rear bars into place. ![[Linked Image]](http://inlinethumb33.webshots.com/46432/2841080590104986527S600x600Q85.jpg) Here's the front bar. ![[Linked Image]](http://inlinethumb15.webshots.com/44750/2724703370104986527S600x600Q85.jpg) ![[Linked Image]](http://inlinethumb34.webshots.com/42849/2146169780104986527S600x600Q85.jpg) In addition to it having a compound angle it also had to be extended because the bars from Trail-Gear were too short. Here's the middle bar... ![[Linked Image]](http://inlinethumb04.webshots.com/45059/2455338060104986527S600x600Q85.jpg) Here's the rear bar... ![[Linked Image]](http://inlinethumb35.webshots.com/45090/2169982480104986527S600x600Q85.jpg) Here's John testing them once they were fully welded in place. After taking this shot, I also climbed on and we both bounced on them to check them. Additionally when I got home I raised the rig using a jack on the rock skid. ![[Linked Image]](http://inlinethumb53.webshots.com/45044/2361707790104986527S600x600Q85.jpg) At the start of the day John had ~1/2 tank of CO2/Argon gas in his tank. Here's the tank at the end of the day... <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> ![[Linked Image]](http://inlinethumb16.webshots.com/20303/2311352240104986527S600x600Q85.jpg)
[Re: off-roader]
#1002830
07/13/10 10:34 AM
[Re: Mudraider]
#1002831
07/13/10 02:25 PM
I used three legs per side, but I think my '95 also used bars that were a little shorter. I got the little triangles that were welded in between the frame and the slider legs for extra reinforcement, too.
You'll be amazed by the Trail Gear steel. It's just flat-out tough. I've ground mine against some tough rocks and came away with just scratched off paint. The steel doesn't even really scratch or get rough. I just shoot some more paint on them and call it good.
Make sure to get some paint onto the ground off/welded areas as soon as possible.
[Re: JohnnyBfromPeoria]
#1002832
07/13/10 03:04 PM
Should have had somebody that knows how to weld do that for you. <img src="/forums/images/graemlins/scared.gif" alt="" /> I mean your only welding to the frame....
Hard Times Don't Last... Hard People Do...
[Re: blueeyeddevil]
#1002833
07/13/10 03:20 PM
That may be a bit too harsh. True, the welds aren't the prettiest I've ever seen. I'm a bit spoiled by a welder that's stupid good. But, structurally, they don't look that bad. There's a couple that look like they need to be ground a little to clean up and make sure good penetation was achieved. The real test will be with their use on the rocks. Besides, it's Ray's truck and if he's happy with it, then none us have anything to say...
[Re: blueeyeddevil]
#1002834
07/13/10 05:05 PM
Should have had somebody that knows how to weld do that for you. <img src="/forums/images/graemlins/scared.gif" alt="" /> I mean your only welding to the frame.... It's not a poseur rig so it doesn't hAve to be pretty, just functional.
[Re: blueeyeddevil]
#1002835
07/13/10 05:44 PM
Should have had somebody that knows how to weld do that for you. <img src="/forums/images/graemlins/scared.gif" alt="" /> I mean your only welding to the frame.... Wow just Wow! What a nice person you are. <img src="/forums/images/graemlins/scared.gif" alt="" />
Michael j
TreadLightly! Trainer
[Re: hazy_daze]
#1002836
07/13/10 06:52 PM
That may be a bit too harsh. True, the welds aren't the prettiest I've ever seen. I'm a bit spoiled by a welder that's stupid good. But, structurally, they don't look that bad. There's a couple that look like they need to be ground a little to clean up and make sure good penetation was achieved. The real test will be with their use on the rocks. Besides, it's Ray's truck and if he's happy with it, then none us have anything to say... Actually none of the welds were cleaned up prior to the shot so what you see is what they looked like right after he got done welding. John's been welding for years and knows how to weld. He asked me up front if I wanted it pretty and functional (longer time) or just functional. I chose functional.
