Re: 4lo in reverse
[Re: 87Raider]
#1003806
07/27/10 02:54 PM
I've had this same problem with a 5-speed SWB. The pin in question is accessed from the top, through the shifter boots. Take the shifter panel off from inside and look down while you move the shift levers.
Re: 4lo in reverse
[Re: JohnnyBfromPeoria]
#1003807
07/28/10 04:14 AM
Sweet...Thank You so very much, i thought i had to take the covers off and go inside the transfer case...Thanks agian
Re: 4lo in reverse
[Re: 87Raider]
#1003808
07/28/10 03:04 PM
Take a look at the FSM. It's the pin they talk about being careful not to drop it... <img src="/forums/images/graemlins/scared.gif" alt="" /> It also talks about how far to insert and how much should come out the backside of the shift rail.
Re: 4lo in reverse
[Re: MontyMcV]
#1003809
07/29/10 07:23 AM
Hello, is it the pin on page 21-17 of the FSM?
Re: 4lo in reverse
[Re: 87Raider]
#1003810
07/29/10 08:50 PM
Re: 4lo in reverse
[Re: fasteddy]
#1003811
07/30/10 06:46 AM
