Re: Gen 1 Mystery Wire [Re: RECON45] #1004021 07/27/10 01:57 PM
StockRaider Offline
I do believe that is your locker return wire. Probably goes to the light on the dash telling you its engaged.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Gen 1 Mystery Wire [Re: StockRaider] #1004022 07/28/10 12:58 AM
ABS sensor ring wire for the locker axle. Should go to the brake backing plate on both sides of the axle. Does nothing for you, since you don't have abs. Tie it out of the way...
Locker pump is not on the axle, so no wires come from axle fot that.
Re: Gen 1 Mystery Wire [Re: fasteddy] #1004023 07/29/10 05:06 PM
RECON45 Offline OP
Here is the wire going from the Axle
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6020 MB (Peak: 0.6555 MB) Data Comp: Off Server Time: 2026-05-29 15:25:40 UTC
