Looking for outside door window seals for 87 Gen1
#1004186
07/26/10 12:57 AM
Im looking for some good used outside door window seals for my 87 Gen1. I still have the clips but the seal itself will not stay in place.
Thanks
2003 limited 20 year anniversary 96 SR 87 Montero SWB=Turbo diesel 4BT T19 4sd with 205 transfer case
Re: Looking for outside door window seals for 87 Gen1
[Re: 87monty]
#1004187
07/26/10 03:37 AM
I realize you want used seals, but I would also check the local body shops for availability as well.
[Re: kewlynx]
#1004188
07/26/10 04:02 AM
Not sure if they will, Its not the soft foam around the door but the hard rubber weather strip that snaps in place to seal out the water running down the window. if you look close you can see what trim im missing. ![[Linked Image]](http://i64.photobucket.com/albums/h163/hyboosa/102_2680.jpg)
[Re: 87monty]
#1004189
07/26/10 05:26 AM
Russell (aka rxinhed) should have one of those. Send him a pm. I just had rtv mine back on the other day.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors 89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels 99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
[Re: K_Raider]
#1004190
07/26/10 06:34 AM
The pieces that I have are not presentable, thus were not offered. Cameron (Cambo) has a parts car, LWB and SWB Gen I pieces are the same. Check around the Classifieds, others are actively parting car there.
Russell
[Re: rxinhed]
#1004191
07/26/10 04:36 PM
Ok will do thanks guys, I still have the piece but it flys off under high wind areas like when a big truck passes by. Ill check with Cambo and see what he might have. If it comes down to it ill use some Goop <img src="/forums/images/graemlins/smile.gif" alt="" />
Thanks.
PHP: 7.4.33 Page Time: 0.499s Queries: 15 (0.492s) Memory: 0.6093 MB (Peak: 0.6790 MB) Data Comp: Off Server Time: 2026-10-25 08:27:02 UTCValid HTML 5 and Valid CSS
