Page 3 of 3 1 2 3
Re: What would happen? Broken Timing Belt or Butterfly [Re: haztoys] #1004766 08/02/10 03:41 PM
DougH Offline
Mitsubishi Forum Moderator
No it will not fix it ...Not to be a jerk ...But your playing with fire and your going to loose and get burned...The ONLY way this can be fixed is to pull the top end off ,,Sorry ... I've fixed a dozen of them over the years ..Its easy for a good machinst to do in know time...Of all the motors on the planet this is one of them that you dont want to have it frag on you .. Cost and finding the parts are just two hard ..You have two things that are going to bite you in the back side..The belt maybe bad and the butterflys ..And you know Doug what will happen if ether one of these lets loose...You have been around here sents 01
Your not being a jerk, this is what this board is all about. Sounding off ideas and getting ideas and options based on the replies.
This discussion has been useful because it is providing some really good feedback on the approach of just disconnecting the actuator as a possible fix. <img src="/forums/images/graemlins/smile.gif" alt="" />
I also agree with you 100% with the risk versus reward of not fixing it the correct way. That is why I replaced the lower manifold myself.
Some people won't want to do this as a fix, or may not be able to afford to do this right away. I think it is a good discussion to consider possible options that decrease the risk of failure. Anything that reduces the risk of the butterfly's failing before a proper fix can be made is a good discussion. <img src="/forums/images/graemlins/kewl.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: What would happen? Broken Timing Belt or Butterfly [Re: DougH] #1004767 08/02/10 04:52 PM
montypower Offline OP
Can anyone else confirm the value of these butterfly valves? Do you think the valves could be removed and shaft holes welded?
I'm not excited about spending $350 on something if it doesn't add performance.
1995 Montero SR - 2" Body Lift, 35" BFG KM2, 2.5" Suspension Lift, Manual Hubs Searching
Re: What would happen? Broken Timing Belt or Butterfly [Re: montypower] #1004768 08/02/10 05:08 PM
hazy_daze Offline
The people that know have already posted about their value. Asking a question like that is kinda like pissing on their knowledge.
Re: What would happen? Broken Timing Belt or Butterfly [Re: hazy_daze] #1004769 08/02/10 05:31 PM
I'm not discounting the knowledge and comments. I truly appreciate everyone's input. It just seems like there isn't conclusive proof about the value of these valves. I'm just trying to have an open mind and look at all options. Don't mean to offend anyone.
Re: What would happen? Broken Timing Belt or Butterfly [Re: montypower] #1004770 08/03/10 03:48 AM
ryany Offline
I don't know that there is any conclusive evidence - without before and after dyno runs to determine actual power and torque levels, everything is pretty much conjecture and speculation. While I stand by my theory of low torque loss, I have a lot of respect for OldColt's knowledge and experience with Mitsubishi engines. He has far more experience with all types of Mitsu engines than I have - my automotive knowledge and engine building experience ranges across the board from small block Chevys to Nissans, Datsuns, Toyotas, and Mazdas, to Opels, air cooled VW's and Hondas, but my 3.5 DOHC is my first Mitsubishi engine.
I guess your best bet is to take all the suggestions and knowledge that you read here and use it to make your own decision. Better yet, get your Montero dyno tested before you do anything and then again after you do whatever repair you end up doing - you can be the first to provide the community with actual factual data.
95 Montero SR
Re: What would happen? Broken Timing Belt or Butterfly [Re: ryany] #1004771 08/03/10 07:16 AM
Well stated Ryan. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I will likely start with disabling / removing the valves. And later replace the lower manifold when I do the head work (valve stems). I'll keep you guys posted.
Re: What would happen? Broken Timing Belt or Butterfly [Re: ryany] #1004772 08/03/10 11:39 AM
To test the butterflys on a dyno is a bit tricky since they are only active at lower power settings. It is hard to get repeated pulls at 20% throttle without a throttle stop. Proper block of wood under the pedal works. But then an automatic transmission hides all low power details due to the way the torque converter functions.
You can plug in and unplug these on a daily or weekly basis, keep a good log of fuel consumption and go with a SOP feel.
I kind of need to get back to testing but mine is a 3.8 so my findings will be a bit different.
Re: What would happen? Broken Timing Belt or Butterfly [Re: hazy_daze] #1004773 08/03/10 01:06 PM
DougH Offline
Asking a question that was already anwsered is far from pissing on anyones knowledge, maybe he missed it in all of the back and forth. I don't think you are trying to be rude, but it could come across that way. Lets not piss in anyone's wheaties. <img src="/forums/images/graemlins/smile.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: What would happen? Broken Timing Belt or Butterfly [Re: DougH] #1004774 08/04/10 04:49 PM
hazy_daze Offline
Doug, I'm not sure if this was directed at me or the OP. I wasn't trying to be pissy, it just happens... <img src="/forums/images/graemlins/ignore.gif" alt="" />
This statement,
led me to believe that he had read all previous posts and still wanted more info from other people. I was merely stating that the people on this forum that knew, for sure, had already answered his questions. And, that noone else was going to be able to refute what they had said... <img src="/forums/images/graemlins/smile.gif" alt="" />
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.004s) Memory: 0.6371 MB (Peak: 0.7589 MB) Data Comp: Off Server Time: 2026-06-11 18:36:09 UTC
