Rear Main leak #1005139 08/04/10 07:16 PM
Torsion Offline OP
Good day all. I have an 89 Raider 3.0 V6 Auto 4WD. I just had the rear main oil seal replaced and trans,transfer case fluid change by a local transmission shop $698. I drove the truck about 40 miles around town and everything was fine. I then drove about 135 miles on vacation and noticed the oil leak had returned. Besides improper installion, what causes the rear mail seal to leak? I guess I'll be taking it back to shop.
89'Dodge Raider 3.0 V6, A/T
LSD, KYB equipped
Re: Rear Main leak [Re: Torsion] #1005140 08/04/10 07:24 PM
Happy Birthday hazy_daze Offline
Bad seal, bad install, high oil level, clogged PCV system, snag on the crank end, as well as others that I'm sure I'm forgetting...
That thing ain't easy to successfully fix in a surgically clean environment... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Rear Main leak [Re: Torsion] #1005141 08/04/10 07:45 PM
FrankR Offline
The seal surface area on the 3.0L crankshaft can become worn after a time and not seal well even with proper installation technique. As Larry said, proper installation can be difficult to achieve for that seal on these engines.
Since you're having a shop do the installation, I won't suggest any ways to work around the installation issue - except to say that there is a seal surface repair sleeve available. It's made by Micro-Sleeve and sold through NAPA stores. Installing it is also an art form and can be problematic if the installer isn't familiar with repair sleeves. Done right, it's the best way to resolve the issue.
Frank
Re: Rear Main leak [Re: FrankR] #1005142 08/04/10 08:51 PM
mxmikie Offline
seal installed backward <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Rear Main leak [Re: mxmikie] #1005143 08/04/10 09:14 PM
Like I said, there's one's I'm forgetting. I've seen that before.
mx, love your new avatar <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Rear Main leak [Re: hazy_daze] #1005144 08/04/10 09:57 PM
Seal spring popped off during install...
Re: Rear Main leak [Re: fasteddy] #1005145 08/04/10 10:45 PM
StockRaider Offline
Eddy, I used to have springs pop off from time to time. Thankfully I read where (I believe it was you) pack them with grease I never had a spring pop off since. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Rear Main leak [Re: StockRaider] #1005146 08/05/10 12:54 AM
Thank Charlie, the old drunken a&p mech who taught me most of the useful mechanical knowledge I know. I just pass it on...
Re: Rear Main leak [Re: FrankR] #1005147 08/09/10 04:19 PM
MI_Mitsu Offline
Frank
Not that I'm against NAPA but a quick Google search showed they are sellign direct online, with 2 different rear seals available for original and regorund cranks. Sellign for about $7 ea here at their site.
Something I may have to look into myself!
Thanks for the tip!
Jim
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6315 MB (Peak: 0.7344 MB) Data Comp: Off Server Time: 2026-06-23 12:43:08 UTC
