Brake cleaner and welding-Safety alert #1005483 08/08/10 06:23 PM
OOP'S Offline OP
To everyone that uses brake cleaner and welds, please read this. It could save your life and those around you,
http://www.brewracingframes.com/id75.htm
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Brake ckeaner and welding-Safety alert [Re: OOP'S] #1005484 08/10/10 01:15 AM
Bent_85 Offline
This is good to know.
Thanks for posting this info!
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: Brake ckeaner and welding-Safety alert [Re: Bent_85] #1005485 08/10/10 01:21 AM
sasnydley Offline
Very interesting. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Brake ckeaner and welding-Safety alert [Re: sasnydley] #1005486 08/10/10 01:31 AM
You can also get chronic bronchitis from burning vinyl floor tile, which is where I got into it. Paid my way thru undergrad school...
Re: Brake ckeaner and welding-Safety alert [Re: fasteddy] #1005487 08/10/10 06:24 PM
8
89IsMine Offline
PHOSGENE!?!? <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
That guy is really lucky even to be alive. That is nasty, nasty stuff <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Brake ckeaner and welding-Safety alert [Re: OOP'S] #1005488 08/11/10 01:55 AM
kewlynx Offline
**ubi apis- ibi salus**
Re: Brake ckeaner and welding-Safety alert [Re: kewlynx] #1005489 08/16/10 03:32 AM
toyrunner Offline
Phosgene is also called mustard gas.
Burning refrigerant will produce this also.
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: Brake ckeaner and welding-Safety alert [Re: toyrunner] #1005490 08/16/10 04:36 AM
4x4Wire Offline
Tri-cholethelyne is a similar cleaning agent. Navy banned it for shipboard use in the early '70s due to health hazards.
Remember the early Teflon non-stick pan coatings?? And, the special tools needed when cooking with Teflon pans??
When burned, the early Teflon coatings did create phosgene gas.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Brake ckeaner and welding-Safety alert [Re: 4x4Wire] #1005491 08/16/10 06:08 AM
Kevin C Offline
They still will create a gas thats very similar to phosgene. Normal cooking temps with teflon can / will kill your pet birds.
Re: Brake ckeaner and welding-Safety alert [Re: Kevin C] #1005492 08/17/10 04:25 AM
trichlorethylene disolves the fat in your body, including some fat you really need, and you die...
Phosgene and mustard gas are two entirely different things, both very nasty...
Re: Brake ckeaner and welding-Safety alert [Re: OOP'S] #1005493 08/17/10 11:59 AM
ForcedAir_Montero Offline
I weld aluminum (w/ argon) and grind it every day. Our shop goes through brake cleaner sometimes at a rate of many cases/day.
I have changed my personal practices! <img src="/forums/images/graemlins/cheers.gif" alt="" />
-Dave D
Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..."
-Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
Re: Brake ckeaner and welding-Safety alert [Re: toyrunner] #1005494 08/17/10 05:28 PM
8
89IsMine Offline
Not to be a smart- <img src="/forums/images/graemlins/butwiggle.gif" alt="" />, but just as a point of clarification... phosgene and mustard gas are not the same and have different effects on the body.
http://www.firstworldwar.com/weaponry/gas.htm Scroll about 2/3 of the way down for a brief description of the two <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric W.
Re: Brake ckeaner and welding-Safety alert [Re: OOP'S] #1005495 08/17/10 06:40 PM
Hey OOp's, Thank you for this. I use Carb cleaner for pre weld rinsing also. I am sure I have used Brake cleaner too but I do stick to cheap carb cleaner that is Toluene and Acetone.
The brake cleaner I have used was either a different formulation or else I was plain old lucky.
The article from mister Brew Dude opens my eyes for sure.
Re: Brake ckeaner and welding-Safety alert [Re: OldColt] #1005496 08/19/10 08:42 PM
At my shop we were being sold a bunch of stuff from an industrial supplier and after reading this i went through it all and canceled a lot of stocked items due to their reactions with welding/burning. I couldn't believe that they were even putting some of these chemicals in a weld shop, it's funny when the new guy in the shop changes the way things have been done for the past 10 years. This hasn't been the first thing either, I've been tearing that place down and making it a proper weld shop and it's come a long way in the 10 months i've been there. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Brake ckeaner and welding-Safety alert [Re: TOASTY] #1005497 08/20/10 02:15 AM
kewlynx Offline
Yeah, I guess MSDS's look too much like garbly-[censored] at first glance, but there's a LOT of information to be had; this is also a VERY good topic for a safety meeting if you hold them now and again.
From this former hazwoper.
Re: Brake ckeaner and welding-Safety alert [Re: kewlynx] #1005498 12/11/10 02:58 AM
Macka Offline
fired this through company lines. We had a noob chlorine gas himself in another incident. He was cleaning a toilet on a rail car and mixed 3 cleaners thinking it would do the job faster.
always working
Re: Brake cleaner and welding-Safety alert [Re: OOP'S] #1005499 08/10/11 08:11 AM
G
GeraldFritz Offline
I am amazed that people are allowed to use these kinds of ingredients!
And the warning labels are generally really little and hidden between the rest of the labeling so you can not really see it unless you look for it!!!
Re: Brake cleaner and welding-Safety alert [Re: OOP'S] #1005500 11/05/12 07:34 PM
joshty Offline
Thanks for sharing this info. It is really helpful.
Moderated by  4x4Wire, PHIL_
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6883 MB (Peak: 0.8332 MB) Data Comp: Off Server Time: 2026-07-09 13:43:02 UTC
