Brake cleaner and welding-Safety alert #1005483 08/08/10 06:23 PM
OOP'S Offline OP
To everyone that uses brake cleaner and welds, please read this. It could save your life and those around you,
http://www.brewracingframes.com/id75.htm
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Brake ckeaner and welding-Safety alert [Re: OOP'S] #1005484 08/10/10 01:15 AM
Bent_85 Offline
This is good to know.
Thanks for posting this info!
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: Brake ckeaner and welding-Safety alert [Re: Bent_85] #1005485 08/10/10 01:21 AM
sasnydley Offline
Very interesting. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Brake ckeaner and welding-Safety alert [Re: sasnydley] #1005486 08/10/10 01:31 AM
You can also get chronic bronchitis from burning vinyl floor tile, which is where I got into it. Paid my way thru undergrad school...
Re: Brake ckeaner and welding-Safety alert [Re: fasteddy] #1005487 08/10/10 06:24 PM
8
89IsMine Offline
PHOSGENE!?!? <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
That guy is really lucky even to be alive. That is nasty, nasty stuff <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Brake ckeaner and welding-Safety alert [Re: OOP'S] #1005488 08/11/10 01:55 AM
kewlynx Offline
**ubi apis- ibi salus**
Re: Brake ckeaner and welding-Safety alert [Re: kewlynx] #1005489 08/16/10 03:32 AM
toyrunner Offline
Phosgene is also called mustard gas.
Burning refrigerant will produce this also.
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: Brake ckeaner and welding-Safety alert [Re: toyrunner] #1005490 08/16/10 04:36 AM
4x4Wire Offline
Tri-cholethelyne is a similar cleaning agent. Navy banned it for shipboard use in the early '70s due to health hazards.
Remember the early Teflon non-stick pan coatings?? And, the special tools needed when cooking with Teflon pans??
When burned, the early Teflon coatings did create phosgene gas.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Brake ckeaner and welding-Safety alert [Re: 4x4Wire] #1005491 08/16/10 06:08 AM
Kevin C Offline
They still will create a gas thats very similar to phosgene. Normal cooking temps with teflon can / will kill your pet birds.
Re: Brake ckeaner and welding-Safety alert [Re: Kevin C] #1005492 08/17/10 04:25 AM
trichlorethylene disolves the fat in your body, including some fat you really need, and you die...
Phosgene and mustard gas are two entirely different things, both very nasty...
Moderated by  4x4Wire, PHIL_
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6402 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-10-21 17:44:50 UTC
