Page 1 of 3 1 2 3
Bleeding brakes-Got a problem #1006534 08/19/10 07:50 AM
O
outdoorfan Offline OP
I started with the LR, then RR, then RF, then finally LF. I got the air out of each one until I hit the LF. It just spews bubbles, and no matter how many times I pump the brake, the bubbles/air aren't reduced. I then go back to the LR and follow the sequence again, finding that each line has some air in it (even though I previously got it out).
I replaced the front calipers a few years ago (Autozone). does this sound like a malfunctioning caliper?
Re: Bleeding brakes-Got a problem [Re: outdoorfan] #1006535 08/19/10 03:13 PM
OOP'S Offline
Did you bleed the LSPV? Do it last.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Bleeding brakes-Got a problem [Re: OOP'S] #1006536 08/19/10 05:50 PM
O
I was intending to do it last, but I never got to it. Somehow lot of air is getting sucked into the LF caliper. I noticed the bleed screw doesn't really tighten unless I really torque on it. It's possible it's not quite sealing off in between brak-pumping sessions.
Also, I pretty much ran the master cylinder too low at one point last night. I should have had more light, as I missed where the mark actually was. <img src="/forums/images/graemlins/scared.gif" alt="" />
I'm not sure if the MC was sucking air, but it might have been. So, the question begs to be answered: Should I bleed the MC just in case, or should the normal bleeding technique at the calipers do the job?
My wife (pumping the brakes for me) was saying that the pedal felt really firm on the other three calipers before working on the LF one. And then the air that is getting in through the LF one makes it so I have to re-bleed the other three. I'll be playing with it again this evening, most likely.
Re: Bleeding brakes-Got a problem [Re: outdoorfan] #1006537 08/19/10 10:45 PM
toyrunner Offline
If you went dry in the master, start at square one. Better safe than sorry. Finally, LSPV as oops said.
As far as the bleeder, pull it all the way out and visually inspect for dirt, debris. Clean and replace
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: Bleeding brakes-Got a problem [Re: toyrunner] #1006538 08/23/10 02:33 AM
Adam F Offline
Try gravity bleeding. Just crack each bleeder open, and leave it. Keep the master topped off. Let it go until each bleeder has a steady drip.
97 4R, stock, daily driver
Re: Bleeding brakes-Got a problem [Re: Adam F] #1006539 08/25/10 11:20 PM
O
I ended up replacing that one bleeder valve screw. Didn't seem to make a difference, but it did seat in more firmly, like it should. The end result was the same: air in the system. So, my mechanic acquantence from church was in town, and he came over and looked at it. He bled the load leveler valve while I pumped the brakes. All the air's out now. I felt so stupid. I hadn't done that one because I was convinced there was a problem in the front left caliper (leaving the leveler for last). I still can't explain what I was experiencing, but now the air is out; so life is good again. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Bleeding brakes-Got a problem [Re: outdoorfan] #1006540 08/26/10 02:12 AM
kewlynx Offline
Air will always find its way to the highest point in a closed system. <img src="/forums/images/graemlins/wink.gif" alt="" />
**ubi apis- ibi salus**
Re: Bleeding brakes-Got a problem [Re: kewlynx] #1006541 08/26/10 03:44 AM
bkg Offline
Sounds stupid since you're done, but buy Russel Speed Bleeders. Best $20 mod you'll ever do... makes bleeding brakes a 1-man operation.
Brian K. Gallus
Re: Bleeding brakes-Got a problem [Re: bkg] #1006542 08/26/10 04:53 AM
kewlynx Offline
Linky:
http://www.russellperformance.com/mc/speed/truck.shtml
Instructions are on the right; several sources offer with a google.
Re: Bleeding brakes-Got a problem [Re: kewlynx] #1006543 08/26/10 06:31 AM
Oyaji_Jon Offline
Brian and Margie,
Thanks for posting these. I wish I had them over the weekend, though, as my ineptitude witht he Mightvac resulted in me using a whole big bottle of fluid and royally hacked me off...
I'm ordering some tomorrow...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.376s Queries: 16 (0.282s) Memory: 0.6364 MB (Peak: 0.7604 MB) Data Comp: Off Server Time: 2026-10-24 14:21:37 UTC
