Re: Do I have LSD rear diff? [Re: FrankR] #1006684 08/24/10 12:40 AM
N
nabsie Offline OP
If you have the headlight washers, more than likely you also have an LSD rear.
Mine HAD headlight washers...I think.
By 'had' I mean that all the wiring is there and the button is on the end of the stalk in the car and pushing the button makes a click noise from the solenoid under the dash but the bottle under the bonnet is missing and there are no sprayers to be found anywhere.
Doing the jack and spin test has given me the answer of having no LSD though. Either that or the LSD is dead.
90 SWB 2.5 TDi Pajero, 31x10.5 BFG A/T on 15" Two Piece BERG rims, ARB steel bull bar, Narva Headlight Upgrade, Thule Racks and Basket.
Re: Do I have LSD rear diff? [Re: nabsie] #1006685 08/24/10 06:48 AM
If it had sprayers, there would be holes for them below the headlights, kinda like the inside of an e-ring clip.
Re: Do I have LSD rear diff? [Re: nabsie] #1006686 08/24/10 03:21 PM
MI_Mitsu Offline
Someone may have alreayd changed the stalk out for a variety of reasons, not the least of which may have been to eventually add headlight washers or for the more variable intermittent wiper function. But to get this I think you also need to add (or change) a relay under the dash for more variable wipers. Still working on this upgrade myself to my 91RS.
The stalk may have also been merely changed to correct a broken turn signal stalk and that was what may have been avaialble at the time from the local yard.
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: Do I have LSD rear diff? [Re: MI_Mitsu] #1006687 08/25/10 12:14 AM
N
nabsie Offline OP
I have the variable wipers but that is the left hand stalk, headlight washer button is on the right hand stalk. my vehicle is right hand drive (Australia) but a Japan import.
There are no holes in the front panel where the sprayers would mount up but I have an after market bull bar and figured the sprayers could have been attached to the stock bumper.
It doesn't really bother me too much that I don't have them because with the weather here in Australia headlight washers are really not required.
It's winter now and the temp today is 20 degrees Celsius (68F)....i.e. really not that cold. <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6101 MB (Peak: 0.6667 MB) Data Comp: Off Server Time: 2026-06-21 18:52:58 UTC
