sorry for the lame question of how to remove steering wheel gen1
#1006734
08/23/10 03:10 AM
i cant get her off. even used pb blaster. The splines appeat to be in good shape. do i need a special tool ? or do i need to fabricate a thick plate that will work as a pry plate by screwing into the two threaded holes on either side of the main threaded shaft. Thanks
91 LWB 3.0 w/300K. Nothing fancy yet...still getting the quirks out and cosmetic fixes.
Re: sorry for the lame question of how to remove steering wheel gen1
[Re: PCMONT]
#1006735
08/23/10 05:49 AM
I have used a steering wheel puller on free rental from the local part store.
[Re: PCMONT]
#1006736
08/23/10 09:34 AM
You could make a plate and use the holes , but the free rental @ Car Zone always seemed quicker to me.
[Re: sparkem]
#1006737
08/23/10 04:10 PM
Thanks guys ! I will get one from the autoparts store. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: PCMONT]
#1006738
08/23/10 06:38 PM
Pulled a billion steering wheels, just man handle it back and forth.
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe 87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
[Re: airbats801]
#1006739
08/24/10 06:57 AM
Yes, just loosen the nut almost all the way (failing to do it this way means you will whack the snot out of yourself with the wheel when it comes loose), and alternate a maximum yank on the left and then the right side of the wheel at the spokes, and it will come loose. Has worked for me every time, including the time I whacked the snot out of myself...
[Re: fasteddy]
#1006740
08/24/10 07:14 AM
