Grinding Starter - lost bottom bolt - pictures
#1007344
08/29/10 11:08 AM
Had a hell of a crunch from the starter on Friday and found that the bottom bolt was missing and the starter was loose as hell. Got a new bolt in there now and re-tightened the top one, she's solid now, but the grinding is still there. Started her up a few times: 3 times good, 2 times grinding, 2 good, 2 grinding. - all started the car. On the last try I kept the key in start position and the starter got through 2 grinding episodes, turned normally for a second or 2 and she started up ok.
My question - Is it possible the flywheel was damaged when I lost the starter bottom bolt or is it that the starter is trashed?
Any advice much appreciated.
Rob
Re: Grinding Starter - lost bottom bolt
[Re: RobCambo]
#1007345
08/29/10 03:25 PM
Thats what it sounds like. That can't be good in Cambodia, what's it like finding parts?
[Re: RobCambo]
#1007346
08/29/10 05:15 PM
Most likely only the starter. The bendix is usually made of a softer material than the flywheel, so it'll give. It is possible that the flywheel teeth will be damaged after extended use of a broken-toothed starter...
[Re: hazy_daze]
#1007347
08/30/10 06:15 AM
Most likely only the starter. The bendix is usually made of a softer material than the flywheel, so it'll give. It is possible that the flywheel teeth will be damaged after extended use of a broken-toothed starter... Thanks Hazy, that's what I was hoping to hear. MudRaider: Can get parts here, but getting good parts is another ball game... It'll be at least a week before I can get to fix this, and the car's my only daily drive - no real alternative. Here's hoping I don't mess things up using it.
[Re: RobCambo]
#1007348
08/30/10 02:06 PM
Can you park on hills so you can bump start it?
[Re: MontyMcV]
#1007349
08/30/10 03:27 PM
Nope. Phnom Penh is mostly flat, and I park the car inside the house at night. Flat at work too. I read somewhere there's an easy-to-reach shield underneath the car that when removed will allow me to see part of the flywheel - I'll be taking an assessment look on Wednesday.
The only way to get the flywheel to move is to turn over the engine, right? If I disconnect the battery and plugs, can I turn the engine over with a wrench or bar from someplace at the front end there?
[Re: RobCambo]
#1007350
08/30/10 03:49 PM
You can turn it via the crank bolt without taking anything else loose. And there is an inspection plate on it...
[Re: hazy_daze]
#1007351
08/30/10 04:12 PM
Ahh, thanks again H. You're full of good news today <img src="/forums/images/graemlins/lol.gif" alt="" />
Stupid question time...Standing at the front of the car, do I turn clockwise or anticlockwise?
[Re: RobCambo]
#1007352
08/30/10 04:34 PM
Which side of the equator are you on?
<img src="/forums/images/graemlins/smile.gif" alt="" /> Counter clockwise, IIRC.
EDIT: Now I'm second guessing myself. Better wait for a second opinion...
[Re: hazy_daze]
#1007353
08/30/10 05:15 PM
Look at the fan. Turn the motor in the direction that pulls air to the rear...
Clockwise, IIRC...
