Re: Grinding Starter - lost bottom bolt [Re: fasteddy] #1007354 08/30/10 05:23 PM
hazy_daze Offline
Doing it that way, it won't make a difference which side of the equator you're on...
<img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Grinding Starter - lost bottom bolt [Re: hazy_daze] #1007355 09/01/10 05:08 AM
RobCambo Offline OP
Follow the fan = turn her over clockwise. Thanks for that.
Ok, damage report.
Around 1/2 of the flywheel teeth are showing bright metal and small scars, but there are no huge chips off them and no teeth are missing. 2 teeth have a <1mm piece missing on the outside (flat front face) of the tooth, and 1/2 of the scarred teeth have a ridge that can be felt next to the bright metal.
The worst damage is shown below. These are not chipped, it looks like they've been hit with a hammer.
What do you think all..... is this flywheel serviceable or will it damage a new starter?
1986 Pajero 2.6l 5spd manual SWB
http://s690.photobucket.com/albums/vv265/RobCambo/
Re: Grinding Starter - lost bottom bolt [Re: fasteddy] #1007356 09/12/10 07:03 AM
RobCambo Offline OP
I can't find a petrol starter anywhere here, so got hold of whatever I could find that's Mitsu. [Linked Image]
Serial numbers 31100-60AC 2 and M001T72483ZC 12v
Is it possible to use parts from this to repair the old one?
I'll be able to tell the if mechanical parts are good, but how about the electrical parts, magnetic switch - would I just burn them out....?
The problem with the starter is intermittent. Sometimes she'll run ok and the car fires right up, and others - the starter spins for a half second then disengages and spins down without starting the car...
Cheers
Rob
Re: Grinding Starter - lost bottom bolt [Re: hazy_daze] #1007357 09/12/10 09:58 AM
Poster: hazy_daze
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />I needed that this morning. You shouldn't have to get up this early n a Sunday morning.
Re: Grinding Starter - lost bottom bolt [Re: RobCambo] #1007358 09/12/10 10:13 AM
RobCambo Offline OP
5am?? Sweet - enjoy, it's 4:10pm here...
I need to remove the stop ring to replace the pinion gear and clutch, is this special-tool-time, or is there a way to get the thing off?
Cheers
Rob
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6130 MB (Peak: 0.6800 MB) Data Comp: Off Server Time: 2026-06-17 01:37:16 UTC
