Prefered Engine Oil for 1993 Montero 3.0 #1007361 08/29/10 04:36 PM
Troy24 Offline OP
Just a quick poll to see what people are using for engine oil. I have been running a conventional oil, Valvoline 10W30 for several years now.
Is anyone out there using a synthetic engine oil? If so, what brand? Also, would it be worth switching to a synthetic oil at 219,000 miles?
1993 Montero SR 205,936 miles. BF Goodrich A/T's Dual Bouncy Seats.
Re: Prefered Engine Oil for 1993 Montero 3.0 [Re: Troy24] #1007362 08/29/10 07:12 PM
TainterRacing Offline
I have conventional oil 20w-50. I have in the past allways run 10w-30 Full synthetic. I think I will go back to the 10w-30. I change it every 2500-3000 miles
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Prefered Engine Oil for 1993 Montero 3.0 [Re: TainterRacing] #1007363 08/29/10 08:30 PM
mxmikie Offline
Re: Prefered Engine Oil for 1993 Montero 3.0 [Re: mxmikie] #1007364 08/30/10 12:36 AM
hazy_daze Offline
Not trying to start a riot, but Castrol is merely a bottling company with a VERY good marketing department. They do not make their own product. For the most part, they don't even have unique additive packages. Their products are by no means inferior, though.
According to most "oil guys" I've talked with, as long as you change your oil on a reasonably regular schedule, use whatever oil that makes you feel good. Or whatever brand that "speaks" to you. In my experience, and theirs, the filter is the more important place to be picky about the product.
Me personally, I use whatever my oil supplier comps me. Right now, it's Delo 400. My fresh rebuild got a quart of Lucas, 4 quarts of Delo 15W40 dynosaur and an OE Mitsu filter.
FWIW, there's a ton of info here.
Re: Prefered Engine Oil for 1993 Montero 3.0 [Re: hazy_daze] #1007365 08/30/10 04:19 AM
I like rotella 15W40
Re: Prefered Engine Oil for 1993 Montero 3.0 [Re: TOASTY] #1007366 08/31/10 03:02 AM
plh Offline
I run this too, and Purolator filters. This guy says to avoid Fram...
Oil Filter Review
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Prefered Engine Oil for 1993 Montero 3.0 [Re: plh] #1007367 09/01/10 09:41 AM
Frumious Offline
At 167,000 miles, I run my 1993 3.0L with Mobil One 5-30 Synthetic for High Mileage Vehicles. The prior owner used a different brand but also 5-30 Synthetic High Mileage. I tried running conventional 5-30 with 20% Lucas, but found the engine did not like it (more start-up tapping from the lash adjusters). Also use OEM filters.
1993 Montero SR 4dr V-6 3.0L Auto "Thunder" (in Alaska)
1960 Bentley S2 V-8 6.3L Right Hand Drive
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6191 MB (Peak: 0.6939 MB) Data Comp: Off Server Time: 2026-06-18 14:21:42 UTC
