Green Flashing lights :GEN 2 dash #1008049 09/08/10 01:48 AM
MBrannon Offline OP
Hello all, silly question. Is it correct for my 4x4 dash lights to be flashing (only the front two tires) during this condition:
engine off
key on
1995 montero ls
I went out this morning and the truck was dead. Will not turn over, will not "click". Battery is up, all the accessories work. It's been pouring rain all day so I have not had a chance to mess with it. The green lights are flashing, I just don't ever remember them doing that before. Thanks for you help.
Matt
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Green Flashing lights :GEN 2 dash [Re: MBrannon] #1008050 09/08/10 02:17 AM
mxmikie Offline
put the transmission in park and the transfer case in 2x
Re: Green Flashing lights :GEN 2 dash [Re: mxmikie] #1008051 09/08/10 02:35 AM
MBrannon Offline OP
Yes tranny is in park(P) and 4wd is in 2H.
Other things I noticed:
-Park and Nuetral relay is clicking
-fuel pump is getting power
-lights turn solid when I put it in 4H
All these things seem to be normal. It's almost like the small power wire that clips onto the starter has fallen off.
1998 Montero
2007 Prius
Re: Green Flashing lights :GEN 2 dash [Re: MBrannon] #1008052 09/08/10 02:43 AM
The flashing lights are a non-issue. Once you get it driving again they should go out. The truck is not getting the signal that it's no longer in 4WD and needs forward/backward motion or inertia against the driveline to tell it as much.
Re: Green Flashing lights :GEN 2 dash [Re: JohnnyBfromPeoria] #1008053 09/08/10 10:51 PM
MBrannon Offline OP
Had to brave out the monsoon today. Stuck my head under the truck to find the little starter wire had fallen off. Stuck it back on and good to go.
1998 Montero
2007 Prius
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6048 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-10-23 16:16:15 UTC
