YJ problem
#1008622
09/13/10 11:50 PM
This won't sound like much to most readers... But I do need to know. I use my cigeratte lighter for lights and other appliances. This weekend the damn thing vanished INTO the dash! What is that all about? Most lighters I have seen are in two pieces, one goes into the hole from the outside and the back (electric part) screws onto it from the inside. This back side has a round screw that takes the 12V positive plug and a flat prong that takes the negative plug. Is this what is in there? Or is the damn MOPAR lighter different? Also how in heck should I go about reattaching it? I do have a new aftermarket one I can use. I can also install a "washer" the size of the lighter base on the outside to hold it forever. It appeared to me that the lighter was installed into a THIN plactic part of the dash. That THIN part seems to have given away from pushing the appliance plugs into the lighter. Any help here is appreciated. I won't be around that Jeep until Saturday. So I'd like to go well armed. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: YJ problem
[Re: BigJim]
#1008623
09/14/10 02:17 AM
The stock lighter is the typical one that threads together. Made by Casco, I believe. Maybe it got too hot and melted itself enough clearance to fall through! Your washer idea to repair it sounds like a good one.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5849 MB (Peak: 0.6336 MB) Data Comp: Off Server Time: 2026-10-21 18:24:28 UTCValid HTML 5 and Valid CSS
