Re: Conferr RoofRack [Re: RECON45] #1008728 09/16/10 02:52 PM
Codyaku Offline OP
Is the rack made from steal or a aluminum?
1990 Montero lwb, 3.0 V6, Custom bull bar, Completely stock on everything else. 186,000 miles
2" inch torsion bar lift. Conferr roof rack with homemade gutter mounts.
Re: Conferr RoofRack [Re: Codyaku] #1008729 09/16/10 03:32 PM
mxmikie Offline
tubing i bought mine for $100.00 9 years ago
Re: Conferr RoofRack [Re: Codyaku] #1008730 09/16/10 04:36 PM
RECON45 Offline
I am wanting to say it was steel because I thought I remember seeing rust on it in areas. The surco I know is allunimum
Re: Conferr RoofRack [Re: RECON45] #1008731 09/16/10 05:13 PM
Yes it's a steel rack. It's one of the reasons I prefer it over the Surco. The surco design is good for most moderate load situations but if you have to carry an entire rear end (diff/axle housing and entire assembly ratcheted to my Garvin Rack) up top like I did on one of our trips out, I'm not sure how well the Surco rack would hold up. From what I saw of them, they're not built to support that kind of load off road.
Another factor that also comes to mind is simply metal fatigue which I'm told with all things being equal is far greater with aluminum than steel.
If these aren't a big factor, then I'm sure Yakima, Thule, and other rack makers would offer aluminum based racks instead.
Re: Conferr RoofRack [Re: off-roader] #1008732 09/17/10 04:41 AM
Codyaku Offline OP
Ok just wanting to know so i can weld some tabs on it when i get it.
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Conferr RoofRack [Re: off-roader] #1008733 09/18/10 09:14 PM
Codyaku Offline OP
One more questions. If i get some gutter mounts for the racks, will the rack which is 4.5 feet be too wide for it to bolt on properly?
Re: Conferr RoofRack [Re: Codyaku] #1008734 09/19/10 10:22 PM
The Conferr racks have numerous slots in the crossbars, allowing the racks to be adjustable. I acquired a rack for $40 about 2.5 years ago sans mounts and have considered various methods involving direct bolting. Get the rack, put it on, and go.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6241 MB (Peak: 0.6995 MB) Data Comp: Off Server Time: 2026-06-23 04:50:04 UTC
