Input Shaft Bearing -- how much play is acceptable [video] #1009245 09/21/10 01:43 AM
yodta Offline OP
hey guys, check this out. have my transmission out for a clutch job and planning to speedi-sleeve the input shaft, and install new seal and also rear main seal while I'm in there.
was on the fence about getting a rebuilt Marlin transmission, but decided to just do the clutch for now and see if I can get by a while longer.
any of you had any experience rebuilding transmissions and would know by looking at this video whether this is too much play for that bearing?
msg - '87 xtracab
Re: Input Shaft Bearing -- how much play is acceptable [video] [Re: yodta] #1009246 10/02/10 12:05 AM
yodta Offline OP
just a quick note -- I installed a new seal in the front cover and reinstalled it. the play diminished significantly, as in, very little/next to none. I think the front cover stabilizes the bearing a bit, as it seems to have a recess machined to accommodate the snap-ring that holds the bearing in place.
I am, however, in the middle of pulling the transmission to replace the seal again. I nicked it slightly putting the front cover back on. I thought it was an unaffected area of the seal, but apparently not. got a nice dual-lip Timken seal this time.
msg - '87 xtracab
Re: Input Shaft Bearing -- how much play is acceptable [video] [Re: yodta] #1009247 10/03/10 10:21 PM
4
4runner4ever Offline
Its normal to have play. The centerpin slides into the small bearing in the crank stabilizing it.
There's only the one large bearing you see and a smaller needle roller bearing that goes into the secondaryshaft.
Black '90 4R
SAS with LC80 coils and LC70 high pinion axle
LC80 rear axle, coils and locker
4.88 gears
2JZ-GE+turbo+intercooler
Re: Input Shaft Bearing -- how much play is acceptable [video] [Re: 4runner4ever] #1009248 10/03/10 10:50 PM
yodta Offline OP
yeah, I thought about that, as well.
I was also surprised by the amount of play on newly replaced rear axle bearings about 10 years ago. I guess I always thought sealed cartridge bearings would be tighter than that.
msg - '87 xtracab
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6004 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-07-16 07:29:51 UTC
