gen 1 cutting out in water problem
#1009301
09/22/10 03:10 AM
hey guys, still having on going prob with going through any half decent size puddles. i have sealed up the dizzy and the leads and replaced the coil pack, cleaned off everything and then sprayed it all with silicon spray and it still cuts out through big puddles.
any suggestions on this one please, as i am at my whitsend!!
it is a 89 v6 auto lwb.
cheers mick
'89' LWB V6 EFI, AUTO, FACTORY 'LSD', SUNROOF(dont work), UHF, RHINO RACKS, WOUND TB'S, GU COILS, REAR SWAY BAR DELETE, 31' M/T's ON 15X8 PATROL OFFSET SUNNYS, 2.5" SPORTS EXHAUST = FUN FUN FUN!!!!
Re: gen 1 cutting out in water problem
[Re: DocPaj]
#1009302
09/22/10 03:15 AM
any chance you are sucking in water through the air cleaner?
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab '15 Subaru XV '03 BMW i325
[Re: zarktheshark]
#1009303
09/22/10 03:59 AM
na man, that well out of the way.
[Re: DocPaj]
#1009304
09/22/10 04:14 AM
Check the main grounds to engine and body.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
[Re: DocPaj]
#1009305
09/22/10 04:29 AM
Is the O-ring between the distributor and the distributor cap still there. I doubt that the original is still there. Part MD611460.
One thing you can try is to get a squirt bottle of water. Start the truck and start spraying at different parts. This will help you narrow down where the problem is.
[Re: MarkG]
#1009306
09/22/10 12:29 PM
I gave up and put plastic bags over the electronics held on with rubberbands.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: Tag]
#1009307
09/22/10 08:33 PM
check for exposed wiring. I had a broken spark plug wire and I couldn't go through any water or it would misfire.
[Re: 0778drz110]
#1009308
09/22/10 11:19 PM
thanks for the input guys, i have had the spark plugs, leads, dizzy cap and coil pack replaced, i have also used a water proof(marine) grease to seal up the dizzy cap where it sit on the dizzy itself and the plugs surrounding it. i checked the O-ring in the dizzy and it seems fine, but i might get it replaced anyway. if all else fails i think im going to get a big tube of silicon and just go nuts and stick it everywhere as i am sick of not being able to follow my mates through the water and finding another way around!!!
thanks for the help, keep the ideas coming, there may be some thing i have missed!
Mick
[Re: DocPaj]
#1009309
09/23/10 01:03 AM
Just wondering, but when it starts cutting out, what do you do to fix it? Maybe a detailed discription of water depth forded, what cutting out means and what you have to do before it's running right again will help come up with more ideas?
[Re: DocPaj]
#1009310
09/23/10 01:03 AM
Have you tried spraying some water on different components while its running?
'87 Raider w/rebuilt 2.6 Weber 32/36
