Re: Need Thermostat for 4D56T [Re: red1987raider] #1009701 09/30/10 01:38 AM
N
nabsie Offline
Two of the three thermostat manufacturers that I looked at list a gasket for the thermostat also. So maybe.
The other one said it had a paper style gasket that also required gasket sealant.
As a part that is only $14 for the thermostat and about $11 for the gasket. Me personally I would be willing to buy one and give it a go. Provided you can buy it local with no shipping costs.
It is a pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> to get to this part once the engine is all together though. Have to remove the timing gear etc.
90 SWB 2.5 TDi Pajero, 31x10.5 BFG A/T on 15" Two Piece BERG rims, ARB steel bull bar, Narva Headlight Upgrade, Thule Racks and Basket.
Re: Need Thermostat for 4D56T [Re: nabsie] #1009702 09/30/10 01:43 AM
red1987raider Offline OP
Nabsie, what do you mean when you say it is difficult to get to this part after the engine is assembled? The thermostat housing is no problem for me to get off. Why would the timing gear be involved? Am I missing something?
1987 Dodge Raider converted to 4D56T
Re: Need Thermostat for 4D56T [Re: red1987raider] #1009703 09/30/10 02:38 AM
N
nabsie Offline
I asked previously if this was part of the water pump assembly which you said it was.
I recently had my water pump replaced because it was leaking and they had to remove all the timing etc to get it off.
Replaced the thermostat at the same time as the original one was looking sad after 100,000kms.
Maybe it wasn't necessary to do this!? Or perhaps I misunderstood and he was meaning he had to remove the belts for air con and power steering and probably the timing belt cover.
Had some other work done at the same time like valve cover gasket and half moon seals.
Re: Need Thermostat for 4D56T [Re: red1987raider] #1009704 10/12/10 11:40 PM
PROBLEM SOLVED. I got a 56mm thermostat from Japan Car Express. The rubber ring that came with it made up the missing 4mm. The thermostat fit the housing perfectly. I appreciate everyone's help in this.
Re: Need Thermostat for 4D56T [Re: red1987raider] #1009705 01/12/11 04:23 PM
metalfaced Offline
hey! not that it matters now, but napa likely has a thermostat in stock for 1987 ford ranger 2.3L turbodiesel, available in different temperatures, but where i am is real cold in the winter, maine gets cold too i hear - get a 195F thermostat, and keep your cooler one, likely a stock 160F for the summer. i bought mine from 'parts source', a subsidiary of canadian tire doing competition with napa, cost me $11. way better than the price for OEM thermostat at $35+!
1953 Willys CJ3A awaiting Buick V6 Fireball and auto trans.
1987 LWB Samurai JX rustbucket
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6137 MB (Peak: 0.6782 MB) Data Comp: Off Server Time: 2026-06-17 10:43:44 UTC
