22RE valve adjustment??
#1010088
10/04/10 12:35 AM
Do most fellows with the 22RE adjust the valves at 8 and 12 hot,or are there any that do them 7 and 11 cold?
Re: 22RE valve adjustment??
[Re: dave1223]
#1010089
10/04/10 03:12 AM
I set them initially 8 and 12 with heavy drag. Warm up, check again and adjust if it's too loose for my liking.
This will also depend a tad on how worn the ends of your adjustment screws are, as they lose their convex surface over time.
[Re: kewlynx]
#1010090
10/06/10 03:20 AM
x2 on the screws. usually they wear a half moon in them, so you go to adjust them and it steps up on the high part of the adjuster. I took mine out, most of them were worn un even and used a stone to round the ends back out.
oh, you can tape the threads a bit and mount them in a drill at a slow speed and use the stone.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5932 MB (Peak: 0.6466 MB) Data Comp: Off Server Time: 2026-06-06 15:46:41 UTCValid HTML 5 and Valid CSS
