Montero Suspension Lift - 2.5" Coils by Coil Spring Specialties #1010562 10/10/10 09:15 PM
montypower Offline OP
Before:
After:
2.5" Coil Springs built to support 400lb constant weight more than stock springs. Made by Coil Spring Specialties. I had them make springs for my 1992 Montero about 8 years ago. They held up well with the off road use (no sagging).
They ride very well on road with no increased body roll. Flex is same as stock (limited by bump stop and shock length). Height improvement is much appreciated off road.
Invoice #98870
Enjoy. <img src="/forums/images/graemlins/smile.gif" alt="" />
1995 Montero SR - 2" Body Lift, 35" BFG KM2, 2.5" Suspension Lift, Manual Hubs Searching
Re: Montero Suspension Lift - 2.5" Coils by Coil Spring Specialties [Re: montypower] #1010563 10/11/10 03:29 AM
So what are they charging for them?
Re: Montero Suspension Lift - 2.5" Coils by Coil Spring Specialties [Re: montypower] #1010564 10/11/10 04:12 AM
Inyo_man Offline
What shocks are you running with the new coils?
Did you say they are a constant rate spring, or are they variable rate?
Way to go on the mod!
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
Re: Montero Suspension Lift - 2.5" Coils by Coil Spring Specialties [Re: Inyo_man] #1010565 10/11/10 04:22 AM
Still have the stock adjustable shocks. The springs are linear rate (same as stock). 400lb increase load capacity will help with carrying the 35" spare and gear. Cost was just over $300 with shipping.
PHP: 7.4.33 Page Time: 0.243s Queries: 15 (0.004s) Memory: 0.6025 MB (Peak: 0.6592 MB) Data Comp: Off Server Time: 2026-06-13 13:21:25 UTC
